Merry Christmas everyone! I'm hoping someone can help with an issue I've been having for the past week or so. I listen to the Bloomington SAFE-T site. For the past week, my scanner occassionally stops on 866.2500 MHz with a dead carrier (no audio). The strange thing is that a talkgroup ID still shows up on the display, but does not show LNK or P25 like it normally does. Seems to be random, and eventually after 30 seconds or a minute of dead air the scanner will start scanning normally again. Needless to say this is very annoying.
Some more info:
* No conventional channels are programmed into the scanners, just the Bloomington SAFE-T site
* No changes to either scanner's programming for about 6 months, and it's always worked just fine up until the past week or so
* Happens on both my 996T and 396T, and also on the RR audio feed for Bloomington. Don't know what kind of scanner that is.
Any idea what might cause this, and if there are any settings I can change on my scanners to fix it?
I do have a conventional scanner with a discriminator tap that I could hook up to Unitrunker or Trunk88 if needed, but I don't really know what to look for.
Thanks!
Kevin
Some more info:
Thanks!
Kevin
