Justin1129
I just got my feed started today and when i start it and listen to it while listening to another scanner on RR it bleeds in with my feed!Is their anyway i can stop this?
I had that problem with my feed. It's probly not just the other feed it's all your audio is broadcast anything like youtube videos anything audio on your computer. your using scancast I am willing to bet. The only thing I did that fixed the problem was I downgraded scancast to the earlier version. (hard to find) I found radiofeed that program seems pretty cool. so far so go for me anyway. If you find another way to fix the problem post it here.
ok so i did what you said and i dont think it worked as far as taking out all the computer sound and when i listen to my feed it repets "echos" its self over and over till you cant under stand what is being said
Do you happen to have the program "Audacity" installed on your computer? I had the same problem when I first became a broadcaster, but was able to correct it through Audacity and actually use it to my advantage.
