Im runnin scannercast for rr.
Im running it on an AMD X6 with 4GB RAM.
Its windows 7 32... and nothing else is running.
When the alpha tags are updating right, the display is correct and in sync.
Then after 5-10 minutes, or sooner, the message will display unable to comunicate with scanner.
Sometimes, it will comunicate for a few seconds, then show unable to, then will, then will not.
When it is doing this, the alpha tags are not in sync.
If you log on to my broadcast, you will see, it will just quit displaying or be scewed up.
Im also using the older usb adapter 20-047. This is the clear orange one.
It works fine for programing and remote....
