I have been running a secondary laptop on Linux for a while now and I wanted to switch my feeds over to it, however I am new to linux and using a non-Dos terminal. I believe I have gotten everything setup correctly but it does not seem to do any thing. Here is my Configuration file. It would be great if someone could check it to see if there is anything wrong.
This is the point were I am not sure if anything is right.
When I go into the terminal this is what I enter and get:# sample DarkIce configuration file, edit for your needs before using
# see the darkice.cfg man page for details
# this section describes general aspects of the live streaming session
[general]
duration = 0 # duration of encoding, in seconds. 0 means forever
bufferSecs = 2 # size of internal slip buffer, in seconds
reconnect = yes # reconnect to the server(s) if disconnected
# this section describes the audio input that will be streamed
[input]
device = dev/audio # OSS DSP soundcard device for the audio input
sampleRate = 11025 # sample rate in Hz. try 11025, 22050 or 44100
bitsPerSample = 16 # bits per sample. try 16
channel = 1 # channels. 1 = mono, 2 = stereo
# this section describes a streaming connection to an IceCast server
# there may be up to 8 of these sections, named [icecast-0] ... [icecast-7]
# these can be mixed with [icecast2-x] and [shoutcast-x] sections
# If you want to send to your own icecast server, you basically copy
# this whole section and put in the values to point the feed to your own
# server instead of the RR information below
# Don't forget, the name [icecast2-0] needs to change to [icecast2-1]
# and 2 and 3 as you add more feed destinations.
[icecast2-0]
# The audio format to encode to, we're using mp3 here
format = mp3
# The bit rate mode to use, the commented out lines are for a fixed bit
# rate "constant bit rate" at 16 bits. I prefer the variable bit rate
# for the sound quality it has and the throughput is very similar on avg
#bitrateMode = cbr
#bitrate = 16
bitrateMode = vbr
# Quality at .1, max is 1.0, but as you increase, so does the bandwidth
# used. For mono scanner audio .1 is totally fine.
quality = 0.5
# Takes the input and mixes it down to a mono output for the feed.
channel = 1
# Cuts frequency response over 5kHz. For scanner feed this mostly
# eliminates hiss and harshness on paging tones. Saves a bunch of
# bandwidth as well.
lowpass = 5000
# Server shown on your RR feed owner page that hosts your feed
# You need to log in to RR, go to Account -> My Live Audio Feeds ->
# click the feed owner page icon at the far right of your feed listing.
# Then you will see all this information.
# From Feed Technical Details, the "Server"
server = audio3.radioreference.com
# From Feed Technical Details, the "Port"
port = 80 # port of the IceCast server, usually 8000
# From Feed Technical Details, the Password exactly as shown
password = 1fkh0swc
# From Feed Technical Details, the mount...remove the leading "/", it's
# not needed in this file. So if it is /999999 make it just 999999
mountPoint = /162376812
# name of the strea
# On My Live Audio Feeds, it's the first part ending in a colon ":"
name = Jefferson and Dodge County, and Watertown Police and FIRE
# On My Live Audio Feeds, it's the part in parentheses in the Feed name
description =
# I don't think this is really needed because RR takes care of links
url = http://api.radioreference.com/js/?key=XXXXXXX&feedId=XXXX
genre = Public Safety
public = yes
Code:
aaron@UbuntuAD:~$ sudo darkice -c /home/aaron/Documents/sc_rr_v014/rr.cfg
DarkIce 0.20.1 live audio streamer, http://darkice.tyrell.hu/
Copyright (c) 2000-2007, Tyrell Hungary, http://tyrell.hu/
Using config file: /home/aaron/Documents/sc_rr_v014/rr.cfg
DarkIce: DarkIce.cpp:150: no section [general] in config [0]
aaron@UbuntuAD:~$
