03-03 Error reading
MicroSD card
Reinsert the MicroSD card to ensure it is fully
inserted in locked in the MicroSD slot. If
necessary, reformat the MicroSD card using the
PC Application “Prepare SD Card for use” option.
Replace the MicroSD card if the problem persists.
Went to turn my 800 on today got error code 3-01 00000002 0011 says see user guide any one have an idea what this means
What make and model of memory card are you using? Also what class is it?
I use a class 4, 8GB SanDisc formatted using the EZ-Scan Digital software, under the Scanner/SD Card pulldown, Prepare Scanner Memory/SD Card for use. It does all the work for you. I've had no problems with the microSD card so far.
I have the same error message myself . . .
I have the same error message myself. I only had this radio less than 24 hours this the 3rd time got the error. Is there a file(s) I can download I'm going to get a new card. Not able to use scanner now cause of the stupid error. I let windows fix the problem worked for a few mints than crashed.
I've had errors too, but have since learned to just wait, even shut off the scanner and try it again. Even in my laptop when I put the card in the reader I will get an error telling me to format it or its not readable. But I just take it out and put it back in and all is well. In the past I would freak and format and start all over again. Now I know not to panic and just try again. Usually its just a simple fix.
Can you do the format with it in the scanner with the software? I have an error of 3-01 00000002 0006
Thanks LOVE AND BLESSINGS
Should be able to but I would suggest a memory card reader.
Usually it'll work either way, but the card reader method will be considerably quicker, especially if you are copying the library and configuration files at the same time.
I have to take out the sd card to put into computer cause when I have my radio off than plug in the usb and open ezscan loads fine>>> but when I am done I exit the ezscan (while the radio still off) it will not safely remove the usb storage if I unplug the usb cable it will give a error and so on. I have to turn off computer to remove the usb cable safely. For now on I use the sd card reader on computer I don't get the errors.
