Hi All,
I am running a skywarn (amateur radio) stream on radio reference. After about 2 days, ScannerCast crashes, and I get a very long Microsoft Net Framework Exception. What does this exception mean, and how can I stop it from happening?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ApplicationException: The sound capturing device is not ready. Is 'Primary Sound Capture Driver' plugged in?
at Istrib.Sound.SoundCapture.CreateCaptureBuffer()
at Istrib.Sound.SoundCapture.Start()
at Istrib.Sound.Mp3SoundCapture.Start(Stream outputStream, Boolean ownsOutputStream)
at Istrib.Sound.Mp3SoundCapture.Start(Stream outputStream)
at ScannerCast.ScannerCast.StartAudio()
at ScannerCast.ScannerCast.RecycleAudio(Object state, EventArgs ea)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3620 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ScannerCast
Assembly Version: 1.0.0.0
Win32 Version: 0.14.10307.0
CodeBase: file:///C:/Scannercast/ScannerCast.exe
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.3614 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Istrib.Sound
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Scannercast/Istrib.Sound.DLL
Istrib.Sound.Mp3
CodeBase: file:///C:/Scannercast/Istrib.Sound.Mp3.DLL
Microsoft.DirectX.DirectSound
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///C:/Scannercast/Microsoft.DirectX.DirectSound.DLL
Microsoft.DirectX
CodeBase: file:///C:/Scannercast/Microsoft.DirectX.DLL
System.Web.Services
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
3jhgmjmp
yeti.mmedia
Assembly Version: 1.0.3688.18337
Win32 Version: 1.0.3688.18337
CodeBase: file:///C:/Scannercast/yeti.mmedia.DLL
yeti.mp3
CodeBase: file:///C:/Scannercast/yeti.mp3.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Thank you very much for your help!
mscorlib
ScannerCast
System
System.Drawing
Istrib.Sound
Istrib.Sound.Mp3
Microsoft.DirectX
System.Web.Services
System.Xml
3jhgmjmp
yeti.mmedia
yeti.mp3
enabled.
For example:
<configuration>
</configuration>
