RR booted my feed, can't reconnect
KSquelch
Central Kansas
My feed stopped due to a RR timeout and I can't reconnect with the server. Here's a copy of my RadioFeed log:
06/29/11 8:13:55 PM - Source Client - RadioReference Timeout
06/29/11 8:13:56 PM - Source Client Disconnected
06/29/11 8:14:27 PM - Source Client Unable To Connect To A RadioReference Server
06/29/11 8:14:58 PM - Source Client Unable To Connect To A RadioReference Server
06/29/11 8:15:29 PM - Source Client Unable To Connect To A RadioReference Server
06/29/11 8:15:55 PM - Source Client Unable To Connect To A RadioReference Server
06/29/11 8:16:24 PM - Source Client Unable To Connect To A RadioReference Server
06/29/11 8:17:17 PM - Source Client Unable To Connect To A RadioReference Server
Any help???
jojo1064
Akron OH
Is there a way to add some type of server status somewhere on the live audio page? This could allow feed providers to not have to search the forums to find out there is a server problem.
ETMegabyte
Suncook Village, New Hampshire
Hah! I didn't think my problem was me. Glad I found this post...
Anyway, it went down for me (forcibly) at 9:15pm Eastern Time. I connect to audio6.radioreference.com if that matters... If it helps, this is the pertinent part of my ScannerCast log:
29-Jun-2011 21:15:36 Write to Icecast server failed Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
29-Jun-2011 21:15:36 Disconnect details follow (for debugging if necessary
Message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
Source: System
TargetSite: Void Write(Byte[], Int32, Int32)
StackTrace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size)
at ScannerCast.ScannerCast.PushClientThread()
--Message: An existing connection was forcibly closed by the remote host
Source: System
TargetSite: Int32 Send(Byte[], Int32, Int32, System.Net.Sockets.SocketFlags)
StackTrace: at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
Socket error: 10054
