What Rob_K said. The .Net Framework file you need is dotnetfx.exe. You can find it here -
Download Details - Microsoft Download Center - .NET Framework Version 2.0 Redistributable Package (x86)
From my notes, here is the route I took to get my t5720 set up.
I started out by following this MagicJack tutorial and installed a clean version of XPe.
Dummies guide: Configure an HP t5700 for MJ using XPe w/SP2 | magicJack and MagicJack Plus Unofficial Support
It will take you through a fresh install and set-up of your thin client so that it will boot right to your desktop with Administrator privileges. Follow it down to the Delete Unnecessary Packages.
One thing I will mention is that I couldn't get the XPe imager file I downloaded to make a bootable USB DOK device on my 8GB USB drive. Luckily I had a 1GB drive sitting here. It uses the FAT file system which has a 4 GB limitation so keep that in mind.
After install, my t5720 C:\ flashdrive had 212 MB of used space and 275 MB free.
To free up some space I grabbed another USB drive I had and downloaded the following files to it.
Remove Media Player -
ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37783.exe
Remove Citrix ICA -
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39090.exe
Remove TeemNT -
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39083.exe
Remove SAM -
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38487.exe
Those are the only files I decided to uninstall but there are more available. You can find the above and more at :
HP Compaq t5720 Thin Client*-* Download drivers and software - HP Business Support Center
It's a two step process to delete the unnecessary packages. Insert your USB drive into the thin client and surf to the files downloaded above. By double clicking each one, the actual uninstall files you need will unpack and copy to the C:\ flashdrive. The files you need to run are stored in the directory at C:\Program Files\Altiris\eXpress\Deployment Server\RIPs. Navigate there and double click each of the Remove files and let each one do it's thing. You will see some DOS windows open, etc. - give each one some time to do its thing. Once everything is run, it's safe to delete the Deployment Server subdirectory which removes the uninstall files and frees up some flashdrive space. A quick reboot and on my system I ended up with 184 MB used and 303 MB free on my flashdrive. A gain of 28 MB. I'm sure more could be removed but that's as far as I took it.
The only thing left to do is install .NET Framework 2.0 so you can run your feed program of choice. Rob_K went the route of downloading RadioFeed and running that. During the install it will realize you don't have .Net installed and will prompt you to download and run the file dotnetfx.exe mentioned at the beginning of this post. If that works, great, you are done. I wasn't that lucky and ran into a not enough flashdrive space or ram drive space or something like that and had to go a different route.
Here's where I stopped taking notes so hopefully I get this right. First, I downloaded dotnetfx.exe and put it on my USB drive. I created a \temp directory on the same USB drive. I then clicked on Start on my thin client, right clicked My Computer, then Properties, chose the Advanced tab, and finally Environment Variables. Highlight TEMP under variables and click Edit. Change the Variable value to point to the \temp directory on your USB drive. In my case I changed it to D:\temp. Highlight and do the same thing for the TMP variable. Navigate back to your USB drive and double click dotnetfx. If all goes well .NET Framework will install. If I remember right, after the install there was an install file on RAMDrive Z: that I was able to delete but unfortunately I didn't write the filename down. My C:\ flashdrive space after Framework install came out to 320 MB used and 167 MB free so the install used up 136 MB of space.
Anyway, from there you can install and run one of the radio feed clients such as ScannerCast or RadioFeed, both work fine on my thin client. It's been over 5 days since I set mine up running RadioFeed and it has been flawless. You can copy a shortcut of your feed program to your Startup folder in Windows, Commit the changes to memory, and that way if you have a power failure upon reboot it will start your feed program back up.
Hopefully, I got all of this right! Feel free to shoot me a PM or post here with any questions or comments and I'll do my best to help...
73, Ron – NR8O
