VHF Commercial Base Station Antenna Model: BF-134
Frequency Range: 134-184 MHz
Gain: 4.5dB
Power Rating: 200 watts
Impedance: 50 Ohms
Max Wind Load: 135 MPH 60m/sec
VSWR: less than 1.5:1 max
Connection: UHF Female SO-239
Polarization: Vertical
Mast Diameter Accepted: 30-62 m/m
Radial Length: 52 cm
Height: 1.5 m
Tran-Max BF-406 UHF Base Station Antenna
Frequency Range:460 ~ 470 MHz, 430 ~ 490 MHz (70 cm)
Gain:6.5dB
VSWR:Less than 1.5:1
Polarization:Vertical
Impedance:50 Ohm
Power Capacity:200 Watts
Connector:UHF Female SO-239
Type:3X5/8 wave length
Length: 1.7m
Wind load: 60m/sec
Mast dia. accepted: 30-62m/m
Opek UHF Band High Gain Base Station Antenna
Frequency Range: 406-512 MHz
Gain: 6.5dB
Impedance: 50 Ohms
Length: Overall length with mount Approx. 70"
DC Ground: Yes
Configuration: 5/8 over 5/8 over 5/8 wave
Channel Master Scanner Antenna
Band:5-Band
Maco: M103C CB Base Antenna
on a 30 Feet Pipe: Antron 99 Base Station Antenna RadioShack: cat. no.20-044 Scanner Antenna
