Audio Graphs on two Web Players
redhat
Ventura, CA.
I have two feeds and used to see independent audio graphs on two web players, each playing a different feed. Now both feed graphs show identically as if both feeds are summed together on both players. What has changed? I like both players to act independently and not show the same combined audio feed graph.
How can I fix it?
kendrik578
Live Audio Administrator
Greensboro, NC
This is a common problem that happens when you have two webplayers going at the same time. Use something other than the webplayer (Itunes, Winamp...etc)
wrenchmonkey
If you left click the graph, it will switch back to the "classic" bars. I don't like the new audio graphic bars, they don't work with stereo or multiple feeds.
redhat
Ventura, CA.
Yes! That fixed it. One click on each graph changed them from summed channels audio spectrum display to independent volume displays. Thanks!!!!
