Scannercast setup with HP T5710 Thin client
kickinkz
New Holstein, Wisconsin
Hi everyone! I've got a small issue regarding using Scannercast with my thin client. I previously was running Scannercast through my desktop and recently picked up a T5710 to run my Magicjack and Scannercast on so I could shut my desktop down at night. I've gone through all of the settings trying to figure out how to do the sound capture, but haven't had any luck with it actually working. The scanner is connected to the mic jack on the client, but Scannercast doesn't list the mic as an option for sound capture. It lists the primary sound capture device, the Ali Audio Wave, and my magicjack as options. Of course MJ won't work, but neither do the other 2 devices.
Any thoughts on how to configure this? My microphone is enabled, and not muted, yet I cannot get it to transmit the broadcasts like it should. Everything worked fine through my desktop using the line in jack.
Thanks!
Phil
