Monitoring private repeater over IP
dado96
New York, NY
Hello I've done a few searches and have come up a little empty handed here. I'm looking for a simple and cost effective way to be able to listen to my repeater that is located in a different state via IP. Just something simple where I can connect a cable to my MotoTRBO repeater and plug into a box, then that box plugs into my network or PC which will allow me to share it via the Internet.
thanks!
RKG
Boston, MA
thanks!
JPS NXU.
It does require that the NXU have a dedicated IP address, and works with a handy application available from JPS called "PC NXU." Once you get through dealing with your ISP on the static IP address, installation and configuration is a breeze.
pir8radio
Download this program
Download this program, "RadioFeed" from here: ProScan
You can see it in action for my repeater if you like... NWI GMRS click the repeaters tab then you will see the player, hit play! If the repeater is inactive it will ID itself every hour on the hour.
All you will need is an old laptop or crappy PC with a sound card, and the above software can stream your repeater.
