Minitor V Alerts, but has not voice
JBloom81
I have a Minitor V that seems to be working almost perfectly. When I first got this pager a week ago all functions worked well. With in the last couple of days it started not broadcasting the message after the alert. If I hold down the reset button I can hear the broadcast. I guess this is PTL mode. Whatever it is, I don;t want it. Any ideas how I can get it back to normal without a programer?
brian209
South Windsor, CT
Push To Listen is programmed per mode setting. For instance, you might program that into setting "D" but A B and C will be set with other settings.
The only way to change these settings is with a programmer.
Brian
firefive76
Kansas
He says it alerts, just can't hear the broadcast, so it wouldn't be the tones. Sounds to me like what Brian said or maybe something changed with the dispatch to where the carrier is dropping and your pager is resetting. Might need to adjust the timing or revert options that control how long the pager remains "open" after the tones are received. Either way, you will need the programming equipment.
nick223
Ottawa Illinois
Or a bad board. I had several like that that or they cut half way out through the message. Had to send them all in to the depot.
joeya7
I have a monitor 5 that isn't getting any voice. Is there any mute or other setting I should be looking for in the programming?
