What a strange response.
:roll:
My thoughts exactly when I read that shortly after he/she made the post.
He/She woke up on the wrong side of the bed or something I guess.
I looked at your reply that set him/her off and I saw nothing wrong with it at all! All fact based and accurate.
As far as I know, the Uniden scanners work the same way with wildcards and an internal database lookup that is done when a TG pops up in the control channel datastream.
If it is found in the radio's database, it is displayed as you entered it. If not found, it is displayed with the TG info and whatever parameters you set for displaying WC's when they are found. Just like you said!
As to the OP's question, setting a Wildcard will NOT prevent your already programmed talkgroups from being displayed and monitored. Those will still work plus any talkgroups not programmed will be displayed and monitored.
You can lockout already programmed talkgroups and they will not be displayed or monitored even when a wildcard is set.
