Any way to use radio for online scanner feed?
Andrewo
With narrowbanding right around the corner I am looking to upgrade my Yaesu VHF transceiver to a commercial radio so I can achieve greater RF sensitivity. Now before I go out and pick up a used HT1000 or something along those lines, can I use the RSM audio adapter to broadcast the radio exclusively through my computer speakers, allowing me to stream the audio to the internet?
cmdrwill
So Cali
You have two questions here.
You need really good receiver, and a handheld receiver is not as good as a mobile radio's receiver.
Then you need a fixed level audio to go to the computer's audio input. Depending on the radio as to the "adapter" or interface to the computer.
You can interface to the HT1000 radio but need a audio transformer and wiring in the RSM connector. The radio's volume control will still be a variable.
CDM and many of the later Motorola mobiles have a fixed filtered audio output made for your application. What we call line level, that is used to feed logging recorders and consoles.
