AllenhurstFire
I've tried searching on the forums for my problem, but I haven't had any luck. I am running scanner cast to provide my feed to radio reference. I am not sending tags, it is just a regular audio 3.5mm plug sending audio to the pc. I have been providing the feed for almost 2 years now without any problems. All of a sudden, it says that there is an "Error-Not Connected" message next to "RR Connection" under the status tab. When I'm under the config tab, it says that it is logged in and scannercast status is "running". I am using version 0.14. Any thoughts or suggestions?
Thank you!
AllenhurstFire
Thank you!
AllenhurstFire
