Best Recieve Qualities Of Any Reciever New Or Old
microo1234
Looking to buy and get back into CB (why?) I was very involved in the hobby back in late 60's and early 70's. I enjoyed the heck out of it. Had a CB shop back then at a young age. Had many different radios and repaired most of that time. Want your opinions before I purchase. I want the best sensitivity, best signal to noise, and best adjacent channel rejection. I'm also looking for best expandability, both channels and clarifer (if the unit is SSB). Any ideas??? Microo
jaythescanman
Red Deer Alberta
it really depends on the radio. Both new and old can be of equal quality, I use a cobra 29 23 channel and a new galaxy dx94hp and the new out does the old as far as sensitivity, but cobra has better clarity with some stations IMHO. Honestly though, no matter what who or where the magic is all in the antenna system.
gewecke
Banned
Illinois
I'm a little biased against cb in general, but if I ever run across another one of these I'll buy it. This is one of the best performing 11 meter radios out there ( not caring about extra channels) ;)
images
73,
n9zas
n9mxq
Belvidere IL
The best radio in the world won't receive scratch with bad coax and a junk antenna. Start at the top and then work your way down.
There's plenty of discussions on here about coax (LMR, RG-8).. A quick search will yield plenty of info there..
As for antenna, that will depend on what kind of space you have. I'm a big fan of 5/8 wave verticals for local work, and beams for playing DX.
prcguy
In the late 1970s I managed a repair dept of a two way radio store that sold everything from Brownings, to Tram D201, Motorola, etc. The best performing radio I ever encountered was the CPI series, CP-400 and CP-2000. I never got to play with a Stoner Pro but I suspect it would rank near the top of the list.
prcguy
jimbr1
Between my current radios- Uniden 520, Realistic TRC-453, Galaxy DX979 and Magnum 257hp, I like the receive on the Galaxy radio the best- just my opinion.
reedeb
Dallas Texas
Best receiving was Realistic or even small rigs with 102" steel whip antenna and good coax. May not have been and the "big radio folks" called a REAL radio, BUT I got out OK and could listen better then most.
I preferred listening then yackin anyways. laughed at the retards.
gewecke
Banned
Illinois
Thanks, I may have to give you a PM since I don't even see them on fleabay. :wink:
( I'd to have hide it from the woman though.)
73,
n9zas
w4wxp
Ky
Uniden Grant XL, Cobra 2000/142 GTL.
KD2DLL
Rotterdam, New York
73,
n9zas
Everything about this post just made me laugh. Im guessing shes not so fond of your ever-growing collection?
JayMojave
Mojave Ca
Hello Microo1234:
The recivers that have a good IF Filter like a crystal filter, or Collins Mech filter, usually have great selectivity, and sensitivy. The Cats Meow is a good ham rig, I use a Icom 746 that has great IF Filters, and
(DSP) in the IF for more filtering. It allows stations on USB to be significantly attenuated when using LSB.
Bit on a more pratical way, I look for a radio with with a good noise blanker, RF Gain, and (ANL) Automatic Noise Limiter, and hopefully again a Real Crystal Filter in the reciver IF circuit. Being able to turn down the RF gain of the reciver is also a big help in some noisey conditions, and attenuating adjecent channel stations that are loud. Some but now all radios have gone to a FET front end that has a cleaner output that has less noise and such.
Mobiling down the raod while listening without engine, fuel pump, heater motor, ignition module, and alternator noise is a real treat. Again a NB is agood call.
There are DSP Filters out there that go between the radio and speaker, that the advertising says it helps reduce noises.
Hope this helps
Jay in the Mojave
gewecke
Banned
Illinois
Not so ever growing you mean. She wasn't around when the basement was full... :roll:
73,
n9zas
Boombox
I'd always heard that the Cobra 148 had the best 'ears' of any commonly available CB radio, and after I bought one in the late 1980's, I immediately had to agree that it's got an excellent receiver. It was much better than my Uniden or my Realistic models.
How the Cobra 148 would compare to the myriads of other brands out there now, I just don't know.
peterwo2e
here is my story on recivers i had ham equipment on ham and cb since the early 80s, would not touch a cb radio cause most if not all had lousy rejection and i was near the cronx bronx i-95 so rejection was a must for me. but not too long ago i had a chance to bench test a browning 3. had that unique ping etc etc. what drew my attention was the receiver it was clear not bleed over. mmm i switch to my icom 7000 and listen on the same channel,mmm i switch back to the browning and that is all it took to buy this radio, i own it and i love it. i read that the browning receiver stage was the breain child of Mr. drake from drake ham radios! this explains it. the most horrible radio receiver i had ever owned was a 23 channel pace ssb and a horrible bleed box rci ranger 2950. but this is just my opinion.
TheSpaceMan
Westchester County, New York
If you can get your hands on a Uniden HR-2510, you will have an outstanding radio that goes from 26 Mhz to 29 Mhz on AM, FM, and SSB. If you get your ham Tech ticket, you are all set for 10 Meters.
k3cfc
Silent Key
Beavertown Pa.
There are two parts to change in a RCI 2950 that will take it from a bleed box to a quality radio. i have two of them and wouldn't part with them for the world.
K3CFC
LZ56
Willoughby, OH
There was a radio called the Courier 1M made back in the '60s. It had a triple conversion receiver, that supposedly was spectacular. Also, a radio called the PolyCom Pro had rave reviews.
A friend of mine had a PolyCom (don't remember the exact model). It had the best receiver I ever heard.
TheSpaceMan
I believe that the the PolyCom 11 Meter radios were built to military specs. They were tube rigs and they came out in the mid through late 1960s. The PolyCom Pro actually had a built in Q-Multiplier in its receive circuitry.
