Win500 Recommended
I managed to get conv freq's programed. Still cant program Motorola type 2 trunked system. The system contains analog and digital (apco 25) voice.
This is the system im trying to program....
Bell FleetNet - Ontario Provincial Government Zone 2 Trunking System, Southeast Zone, Ontario - Scanner Frequencies
I don't know whether you are using programming software with your radio; however, I strongly recommend Win500 for this task. As you can see in the following link, Win500 is eye-friendly because all of the fields are on one screen.
In other words, you can see the TSYS (Trunking System) & associated Talk Groups (channels) in one visual field.
For the larger radio system that encompass a wide expanse of radio sites/towers, you have to figure out which ones will affect your area of monitoring. In Motorola systems with all, none or mixed P25 digital, you can load only the control channels to increase efficiency. However, remember, when these trunking systems are loaded with the control frequencies, they cannot exceed 32 frequencies.
Here is a great example of Win500:
WIN500 - UtahRadio
When I reviewed the system you included in your post, I saw a mixture of analog, digital & encrypted talk groups as indicated by (A, D, or E).
If you want to locate whether your location intersects with the tower sites, you can go to the top line on the system in question. To the right, upper section, you will see something that says "RR locations." These should show up on a map which you can increase or decrease in size.
Of course, I realize that this information is likely foreign to you and takes some time to digest. Hence, this is one of the main reasons to use forums, obtaining assistance.
Welcome to RR.
