Windows 8 Issues
snpr1992
Palo Pinto, TX
I was wondering if someone could help me I program the radios for our local fire departments and I just invested in a new laptop with windows 8 on it. I installed commercial series CPS R05.16 as an administrator and I have tried running it as an administrator and in compatibility mode. I keep getting the error message unable to open the controller. I also installed professional radio CPS R06.12.05 using the same method and so far it works fine. Any help on this matter would be appreciated.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Are you using a USB cable for the Commercial Series? These suggestions are based on my experiences with a USB cable.
First, make sure you have the latest drivers for the Prolific 2303 chipset. They can be found at prolific.com if you need them. Anything else may cause problems.
Second, make sure the programming cable is plugged in and recognized by the computer before you run the Commercial Series CPS. You may have to go into the device manager and confirm this.
Third, I found with the Commercial Series CPS that you have to set the comm port every time you run it. Just fire it up, go to Edit ---> Preferences and set the Comm Port EVEN if it looks like it is already pointed at the proper one.
snpr1992
Palo Pinto, TX
Well I haven't even made it into the program. It gives that message at the launch screen. I do have a USB cable I've been using. Is that error message a driver issue or because the program won't launch is it a compatibility issue?
Thanks for the help
snpr1992
Palo Pinto, TX
Well, I went back and re-read your post, then went and downloaded the prolific 2303 chipset and hooked a radio up to it and low and behold it worked.
Thanks a lot.
KK4MSC
Mount Airy, NC
Gentlemen, thank you. You saved me a bunch of aggravation. Mine is working now. Give yourself a pat on the back....
I read there were some cloned Prolific chips that were showing up in USB to serial adapters. Prolific made a change and the new drivers did not work the the bogus chip set.
CommJunkie
FM19gt
If you have a cheap chinese USB programming cable off ebay, you need to use an old version of the prolific driver.
