How to obtain 25kz entitlement keys
cabletech
Puget Sound
In order to obtain the 25kz keys that will allow for wide band programing, their is a narrow band training that you have to take.
There are five keys.
First off you have to have a MOL account. Go to traning, click on the LMS drop down, then in the upper right , enter narrowbanding, as one word, in the search box.
It will bring up the following: PRD0001.00E - FCC NARROWBANDING MANDATE TRAINING
Click on it and complete. Wait about 4 hours for the record to get logged into the system, then go to
case magement and open a case stating that you have taken the training, include your cert #, and that
you are requesting the keys.
Within 24-36 hrs, you will recieve a e-mail about the ablity to order the keys.
At this point, go buying center>search catalog, enter in the part number and place your order.
Waring, the system is not setup to order all the keys at the same time, they must be ordered indivially.
After placeing your order, within 24-36 hours you will recieve e-mail with the key code.
DO NOT LOSE THEM, THEY ARE ONLY ISSUEABLE ONCE.
Here is the part numbers:
Mototrbo – HKVN4046A
Professional Series – HKVN4180A
PR860 – HKVN4181A
Commercial Series – HKVN4182A
CP185 – HKVN4183A
Arizona
sweet thanks! I opened a case a week ago asking for this information and still haven't heard anything back from them.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Just tried to take the course, but it is not to be found at LMS. I think that I have to contact Customer Service to have them enable the course for our account. Oh, what fun!
CommJunkie
FM19gt
Now the question is, if you go through all this for the newest versions of the CPS, will you need to do this all over again when they come out with another new version of the software down the line?
SteveC0625
Probably not. The entitlement keys should work with succeeding versions of CPS.
I don't think even Motorola wants to deal with all the complaints they'd get if they were to make us get keys for each new revision.
cabletech
Puget Sound
I just tryed it and it is there. You have to use training>LMS then the search box up in the right corner.
It will bring it up. Click on the highlited course.
The information that I have recieved is, this is a one time hoop to jump thu, other then maybe a differant key depending on what software you have/will buy.
Once you take the course you should be ok.
The info I have is that this hoop is a one time deal, then you just have to check availablity for any other programs that you buy.
SteveC0625
The info I have is that this hoop is a one time deal, then you just have to check availability for any other programs that you buy.
Still had to call Customer Service. They had to make a minor adjustment on our account for the course to appear. All is good.
I asked about the "one time deal" and she wasn't sure. Said I'd have to talk to a different department to get a firm answer.
chrismol1
P25 TruCking!
enter an entitlement ID and the CPS contacts its license server (internet connection required) and attempts registration of your account as long as entitlement attached to your account it should be active
hmmm, this attempt from motorola to have the CPS connect to internet, just for entitlement ID's right now, but makes me think this could be something we could be seeing more of in the future and not just for entitlement ID's
mancow
N.E. Kansas
I just finished the on line training course in MOL for WBFM. The video completed and there was no other option but to close the course. When I go to the training center nothing comes up. Does something appear in my account somewhere after a while or what?
Ah never mind. Popup blocker kept it from opening.
N4KVE
PALM BEACH, FLORIDA
The entitlement key from "M" is good forever, through any future upgrades. However, there are talented people who have found a way to generate the wide band "fix" so you do not have to jump through hoops. However, this fix needs to be changed every time CPS is updated. I've used it since the rule came into play, & never had a problem. It's easily found on the internet, on a Canadian site, & perfectly legal to use, as it didn't come from Motorola. Many people who do have legit CPS use the fix because "M" makes it so difficult with the class & all.
TDHG4U61
Denver, Colorado
Entitlement key
Also, correct me if I am wrong, to install the CPS on a different or additional computer you must order a new key.
N4KVE
PALM BEACH, FLORIDA
Yes, but since you will have already taken the class, it should be easy. Just tell them you have 3 laptops, & they will send you 3. My friend gets 10 at a time.
rescue161
KE4FHH
Hubert, NC
Yep. That's what I did. Initially, I ordered 5 keys, but I changed operating systems on all of my computers with fresh install, so I lost all of my programs. I just ordered another 10 keys and it went through, no problem. The keys are good forever until you use them.
The bypass fix works great, but is a pain to have to add the fix every time you upgrade your CPS, so the EID is a better route for me.
dfb8085
Cumming, Ga
Ok I have an entitlement ID . Where or how to I enter it into the Ver 13 CPS ? I do not have my copy of the software yet but will have in a couple of days
CanesFan95
FL
I think these instructions need updating. Maybe the website has changed? When you hover your mouse over "Training", a drop-down appears that says "LMS Training Center". When you click on "LMS Training Center", a new browser window opens and there's no where on the upper right to search for the word "narrowbanding". Instead, on the right side, MIDDLE of the page, there's a SEARCH box and a drop-down with some options. You can type your word search and click the magnifying glass to run the search.
Or, there's an Advanced Search link you can click on. Problem is, no matter how I search, I get nothing. No matter whether I search for "narrowbanding" or "PRD0001.00E" or "FCC NARROWBANDING", I get nothing. Zero results found. So I'm not sure what's going on here. I've already signed the software license agreement and it was accepted.
Forts
Ontario, Canada
Go to Buying Center -> Search Catalog -> Search By Model Number.. and enter HKVN4046A. I just ordered the entitlement last week, took about a day for the email to come thru.
