trouble setting up scannercast
feedus
Perkasie PA
Hey all,
I have searched this forum and cant find what my problem is. Im very fustrated!!!!!
The computer that I had running my feed suffered a fatal HD crash. I sent it out and had a new HD put in. XP was reinstalled. I have .Net Framework 4 Client Profile and Extended. when I go to start scannercast I get the following error message
Application has generated an exception that could not be handled
Process ID=0xa74(2676) Thread ID=0xf18(3864)
Click OK to Terminate App
Click Cancel to Debug
What am I doing wrong.
please help
feedus
Perkasie PA
well that didnt work I get an error when downloading radio feed
Error 25007. Error Occurred while intializing fusion. set up couldnt load fusion with LoadLibraryshim(). Error 0x80131700
ProScan
Software Provider
Ontario, Calif.
Google search "fusion LoadLibraryshim". It appears that it has something to do with .NET Framework 2.0 and there is a fix for it. Both my Radiofeed and Peter's ScannerCast requires .NET Framework 2.0 installed. Don't do anything with .NET Framework 4.0 or other versions as the .NET framework versions are designed to coexist.
feedus
Perkasie PA
Thanks guys, I googled it and here is the fix incase some one else has the same problem
click Run
add %SYSTEMROOT%\WinSXS
find the Policies Folder and Delete it.
download .NET Famework VS2.0
and it should work.
