AR82 00MK3 USB Cable from the 'Bay
So Far Away....
I recently stepped up from an AlincoX10K(unblocked) wide range receiver
to the AoR 8200MK3-G- version..
First big YIKES that hit me was the cost of support/expansion gear..long story to short
I kept looking for a few weeks on the bay,maybe a used cable would find its way on there..
None to be found...
Then this one pops up from the UK...
AOR AR8200 USB Computer Control Cable Similar to CC8200 | eBay
I order up..about a fortnight passes and on Saturday afternoon USPS drops it in my box.
Im using the free JAVA app for programming but I will Confirm that the cable will Up/Download with ease,im running XPPro SP3..I did Not install the drivers,it was true plug n play..
Thumbs Up from me.And it was about half what the OEM unit runs for...
dkf435
Sweet Home/Foster OR
Every once in a while a HP Jornada cable pops up at the Goodwill store here ,the only catch is that some of the cables have a pin tied to ground and that needs to be cut sometimes, but the connectors are the same.
If you want to tap the discriminator, make an interface or a Scout cable get one or order one from AOR.
David Kb7uns
tulsascan
Tulsa
thanks
found one on amazon used 11.00 plus shipping cost me 15 bucks great deal save me a ton of money on Radio Referance
dkf435
You must still wire the cable up to a MAX232 chip or some other level converter, but if you are like me I have half a dozen around here including the old AR8000 cloning/RS232 interface that will work.
Not sure if he still has some but I got some from Taka down in Torrance a few years ago.
David Kb7uns
tulsascan
Tulsa
thanks for the help DKF435 unfortunly what i ressieved was not the right connector so back to the seach i will save the pin out.
ok1iko
cable
David Kb7uns
Hi David,
I have a same problem with this cable. When I connect it to AOR8200MK3 then from speaker go growl and my S-meter lost with signal. I thought so that it is problem with ground. On which point of cable I have to cut tied pin? Thanks a lot for reply.
Bob OK1IKO
