Never mind, got it fixed.
spectr17 Member Joined Nov 1, 2003 Messages 177 Location CA Apr 24, 2013 #1 Never mind, got it fixed. Last edited: Apr 24, 2013
B bruuuuce Member Joined Dec 12, 2013 Messages 2 Location Potosi, MO Dec 14, 2013 #2 What did you do to fix it?
O Onetechyguy Member Joined Nov 5, 2012 Messages 37 Location Bridgeview, Illinois Dec 21, 2013 #3 I'm having a problem also Hi, I noticed that you had a problem with scanner cast & Microsoft.net framework. I am also having the problem whenever I try to start the application. How did you fix it? Thanks. Rick KC9PXL
B bruuuuce Member Joined Dec 12, 2013 Messages 2 Location Potosi, MO Dec 21, 2013 #4 I gave up never could get it to work, I ended up using an older windows xp box I had
W wtp Member Joined Apr 3, 2008 Messages 5,984 Location Port Charlotte FL Dec 22, 2013 #5 yep now that is the fix for windows 7.
spectr17 Member Joined Nov 1, 2003 Messages 177 Location CA Jan 8, 2014 #6 I uninstalled and reinstalled scannercast to fix my problem. sent from my tin can & string
