Loud squeal on OK-WIN system during tornado
Was there, heard it, dealt with it, - got the T-shirt.
The Moore site of the OK-WIN network went smooth *** down during and immediately after the tornado. All of the units we had using 800 HT's lost all coverage, had to move all our units back to our own UHF radio system. (We have coverage problems of our own down there, that area is not really in my normal service area - that may change after this deal!).
The site seemed to go up/down a couple of times which was good - no, it was actually BAD!. When the Moore site came up, it was out of GPS lock. The GPS lock ensures all the transmitters on the simulcast system are synchronized. When they are not, you will hear heterodynes generated between the different transmitters. Depending on exactly where you are standing, the squeal from the heterodyne will be better or worse. If you are standing in just the perfect spot, you will hear two transmitters completely out of phase with each other - which means you hear NOTHING at all. That happened a LOT. Because of all that, we completely avoided using the OK-WIN network to ensure out guys could (sort of) talk to each other (again, see note above about not our normal service area).
After several hours of dealing with the squealing transmitters and the up/down Moore site, the Motorola bunch finally arrived to "save the day". I heard they had arrived, didn't really hear anything get better for hours (and hours). Finally, in the early morning hours the simulcast seemed to improve somewhat. Must have gotten the GPS lock working again. Was still hearing minor heterodynes early yesterday morning. Only problem left was busy signals. Needless to say, when you have a thousand rescue workers trying to use sixteen channels you will have those. One Norman transmitter was apparently down due to a hardware problem. Not sure the Norman radio tech was even aware of it. When one TX is down in a simulcast system, none of the sites can use that channel. To get that channel running again (see note about busy signals) the Tulsa guys apparently dropped that channel off the system from the Norman sites.
I can tell you, had the Norman system not been up and running (and working) there would have been several long stretches where the OK-WIN network would have been completely unusable in the damage area. We are looking at our UHF infrastructure and reviving plans to add sites down south that were shelved due to financial concerns.
As somebody said once, never led a good crisis go to waste. Might get some more money for comms this year!
