ARC433 Error Message
DotNM
Watchung, New Jersey
Has anyone seen this message from the ARC for Radioshack PRO433/528 software? I purchased it from here on the RadioReference website and haven't been able to get it to download from RR.
ARC433
FaultCode: SOAP-ENV:Client
FaultString: Operation 'x' is not defined in the WSDL for this service
OK
Is there any way to fix this? I've verified firewall settings and have uninstalled/reinstalled. I have a premium subscription as I'm a feed provider, and I've tried the evaluation copies of other ARC software versions and it works okay in those - the problem is only in the ARC433 version.
RonnieUSA
Rowan County,KY (Morehead)
Did You try downloading it from Butel?
System Requirements:
Windows XP/2000/Vista/7
Radioshack PC interface cable 20-047 or 20-546 or the GRECOM USB cable
IMPORTANT: Radioshack cables 20-048 and 20-049 do NOT work with the Pro-433/528/2051
Use other cables at your own risk! Use the ARC433 demo version to verify communication works before purchasing the software! All software sales are final.
RadioShack PRO-433 PRO-528 PRO433 PRO528 Software
DotNM
Hi RonnieUSA,
Yes, I already tried downloading it directly from them but I have the same problem. Oddly, it's only with that version of the software. The other programs for the other scanners have no problems at all.
w2lie
New York DB Admin
Long Island, NY
I'm using BuTel's ARC433 v 1.22.01 and can import from RR with no problems this morning.
DotNM
I couldn't find a copy of that file anywhere on my system, hidden or not hidden.
I actually found the files and deleted them all then restarted the computer but I have the same problem. I also uninstalled the software, rebooted and reinstalled but am continuing to have the problem.
Here's the info from the faultlog file in the same directory.
06-30-2013/12:35:18
Application: 250
Key:31633123
USer: DotNM
PW:[removed for security]
Version:4
<S:Envelope
xmlns:Enc="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:S="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:XS="http://www.w3.org/2001/XMLSchema"
xmlns:XI="http://www.w3.org/2001/XMLSchema-instance"><S:Body><S:Fault S:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" XI:type="S:Fault"><faultcode XI:type="XS:string">SOAP-ENV:Client</faultcode><faultactor XI:type="XS:string"></faultactor><faultstring XI:type="XS:string">Operation 'x' is not defined in the WSDL for this service</faultstring><detail XI:type="XS:string"></detail></S:Fault></S:Body></S:Envelope>
Butelsoftware
Dayton Hamvention
Try re-installing a new copy. Also doublecheck you entered the correct username/password in the RR import window and make sure that ARC433 is allowed full internet access in your firewall or as a test disable the firewall.
Gommert
Butel Software
