I semi-successfully setup SDR#, DSD, UniTracker with a single FCDP+. Everything works but the bug in the Trunking Plugin as it does not shift back to the control frequency after the call finishes. I will be switching to a two dongle setup shortly since there seems to be no fix discussed for this.
My question is do trunking radios have two receivers? Does one sit on the CC and the other do the call TX/RX? If they did, I'd assume the CC RX would be muted during TX on the Call channel, but still. I find it overly complicated to require two RX, which is why I ask.
Thx
Thx
