Polty, you'll need a good ground for the equipment to be protected properly.
I prefer a "trident" looking configuration with a total of five copperweld (copper clad) ground rods, 8 feet long, (I prefer at least 5/8" diameter) sunk below the ground at least four inches, the three being sunk a little less than 8 feet apart to allow for connections. Lay the other two across the three sunk rods and connect them with large bronze clamps or use the "explosive weld" to connect them about six inches below the tops of the rods or less if you intend to use the horizontal bars as a bus.
Next run at least a #2 solid copper wire to either under the house if you have a crawl space, or into the attic if you are on a slab. Use conduit to enclose the wire, metal or UV resistant PVC up the wall into the attic. (I prefer 2-0 stranded copper, green insulation.)
Run the lead to a buss inside the attic or under the house and then tie all your grounds to it. With the buss, you are not limited to what size wire you can run for individual connections nor limited to how many leads you run to the outside ground.
Be sure to backfill the holes and trenches so the lawn mower won't find them.
Also, make sure the neutral at the meter base and the ground buss inside the distribution breaker panel is good, clean and well connected, and tied in to your ground system.
I know this will cost a little bit, but the benefits will outweigh the hard work and the alternative.
