It's time again for the NC State Fair!
For those with scanners the following analog statewide Event talkgroups on VIPER will be used for this years NC State Fair:
Statewide Events Alpha 1 (TG 784) = LE Patrols
Statewide Events Alpha 2 (TG 816) = Major Events Channel
Statewide Events Alpha 3 (TG 848) = Dorton Arena
Statewide Events Alpha 4 (TG 880) = Fire/EMS/Red Cross
Statewide Events Bravo 1 (TG 912) = LE Traffic Control
Here is a copy of a traffic "post" map from years past. I believe it should be pretty accurate for this year as well.
http://qsl.net/ke4znr/NCFair/NCSHPStateFairPost.pdf
Edit: Here is an NC State Fair Uniden HomePatrol HP-1 "hpe" file to import into Sentinel:
http://qsl.net/ke4znr/NCFair/2012/2012 NC State Fair.hpe
The file includes all of the analog/digital statewide events talkgroups with the majority "avoided" (locked out) except for
the ones listed above that will be in use. The only tower site not "avoided" (locked out) is the Wake County Simulcast. Which
means if you are trying to monitor outside of Wake County/Central NC you will need to go into Sentinel and un-avoid the sites nearest
you. Don't worry about the 2012 label...talkgroups should be the same from last year.
Another Edit: here is a Freescan file for use with Uniden XT Scanners:
http://qsl.net/ke4znr/NCFair/2012/2012 NC Fair Freescan.996
Again don't worry about the 2012 label...talkgroups should be the same from last year.
Any updates/corrections please email KE4ZNR@radioreference.com.
Thanks and Have a good time at the Fair!
Marshall KE4ZNR
Marshall KE4ZNR
