I have 2 of these BC350A's that I use for a scanner stream. I noticed recently the squelch is stuck open on one of them and turning the squelch knob does not fix it. I tried different frequencies in different bands and it's the same on all of them. Even unplugging the antenna doesn't fix it, so I think that eliminates a local noise source. I pulled up the local weather radio frequency and it sounds fine, no white noise behind the signal.
I popped the hood on the unit and noticed some internal pots, but I don't know if/which one controls the squelch further. Obviously there could be other issues with the scanner, but figured I would start there. I've searched the forum but have not found any specific reference to these pots. The ones I see are labeled as L6, L8, L11, L12, L13 and RT1. I don't want to start adjusting them at random and make things worse.
Any help would be appreciated. Thanks!
UPDATE: I put the radio back together and now the squelch works. Not sure if there was dust in there somewhere or a heat related issue, but it's working now.
