heliocopter freq question
hippieman556
Philadelphia,PA
Does anyone have frequencies for medical and non medical heliocopters ? I have been seeing and hearing a lot of heliocopters in the willow grove and abington pa area.
Don't know about your area but here in NE OH they coordinate themselves on 123.025 MHz AM besides using company and hospital frequencies.
trap5858
Doylestown PA & Milton DE
Many corporate helicopters transit that area daily.
The medical helicopter frequencies are easy to obtain from the data base and I think the media (TV) helicopters are in there too.
Military helicopters would be just over flying the air space these days and would be in contact with Philly tower.
mattl3320
pa
well here in pa I have the following helicopter channels.
123.250
123.0750
123.0500
128.950 helicopter plant in chester co pa.
123.100 psp, medvac, cap search and rescue channel.
135.9750 news helicopters nbc 10 abc 6 ect for air to air at events they are coving.
155.3850 pennstar dispatch and to helicopter inflight to base.
155.2200 medevac helicopters
155.3550 pennstar to other helicopter, ground ambulance.
125.1500 reading airport app hearded when pennstar was base there.
126.200 military tower
124.3500 phil app
123.800 phil app
122.950 Unicom at most airports in the area
122.700 chester county airport where helicopter plant is located.
123.000 Unicom
123.4500 air to air
123.800 phil app
hope this helps get u started there maybe more in and around your area . these can be heard here along the eastern side of pa.
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
123.025 is a helicopter unicom freq.. Good for listening when more than one helo is present or you are in a metro area.. It's good listening countrywide
echo676
Exeter Pa
Medavacs in Berks County area
Recently moved back into area and really not hearing anything on Medavac freqs. Used to be very busy a few years back. I updated all my freqs and still not hearing much like I used to. Any suggestions would be very apprciated.
trap5858
They are out there. Pennstar seems to be the most active on radio right now. They do their pager tests at 0700 and 1900. I think some of the services use alpha pagers to alert their crews and do not always tone dispatch.
MedEvac split into two services a couple of years ago so two frequencies are needed to monitor them.
mattl3320
pa
well I hear helicopter almost daily here in my area. skycare is no longer flying as there where shut down at brandywine hospital a couple of years ago they where very active in this area along with pennstar and medevac and lifelion. I use what I have list above so as to help with hearing more I can try to help . what type of antenna are u using if it behind the set or duck antenna then you will not here that much. if u put up a ground plane antenna with good coax like lmr 400 out side up at 30 to 40 feet u will here a lot more here at my home I have heard choppers as far north as southern new York city and new jersey on good weather days. also It depends on the time of day u are listening most happen between 7 am - 5pm Monday - Sat for most of my listen its the helicopter plant at chester co and news choppers coving the area also look hear in radioreference under airports try putting some of the Unicom channels and air to air in like 123.4500 and 122.950 and mybe some tower channels if u have one at your local airport also try open the squelsh up until u hear the static noise and then turn it back until the noise just goes away and see what happens. the antenna I have is radio shack ground plane which can be bought in there store along with the tripod and mast for the antenna the lmr 400 cable can be bought at scanner masters or universal radio with the end on it or u can add the your self. this coax runs about 1.00 a foot or so not cheap but worth every penny.
Cunnerman
Monroe County, PA
Listening to an accident/medevac call on my scanner this afternoon and it seems that the helicopter frequencies that worked previously (Lehigh Valley Medevac 464.2000, CTCSS 82.5; and 464.2000 CTCSS 107.2) are no longer in use??? I could hear the firemen and EMTs talking about the LZ, wires and obstacles to avoid, etc but none of the chopper comms/responeses. Previously you'd hear the pilots mention lbs of fuel, flight times, number of people on board etc. Any chance the start of the new year has led to a change???
echo676
Exeter Pa
Medavacs in Berks area
I can hear Penn Star.......usually nothing but the dispatch tones & pilots position. I also get Life Lion at times. What happend to the rest of what used to be out there and easily heard ? Are they going to a Med channel now to report ? I have birds going over my house often and don't hear much like I did a few years ago ?
echo676
Exeter Pa
Meds in Berks
I think my antenna & coax is sufficent. Still working on mounting to roof gable on new house. But I have a commercial VHF 6 ft whip antenna connected to each of my two scanners leaning up against outside walls with 1/4" superflex coax. Not perfect but as soon as it gets warmer I will mount outside.
trap5858
PennStar has at least two transmitter locations that the dispatcher can select from. One is on a tower in the roxborough section of Philadelphia and the other is out near Lancaster.
Quite often when the helicopter is doing a scene call (accident or other rescue) they switch to a local ground contact frequency for landing zone information. Sometimes you can hear them give a brief patient report either to the dispatcher to relay to the receiving hospital or to talk directly to the trauma bay.
mattl3320
pa
ok here is what i have from a couple of years ok when i was active with the ems/fd here.
151.52750- Jeffstat
464.200 Lehigh valley medivac
155.3550 life lion
155.2200 life lion
154.06250 mid atlantic medevac
155.2650 stat medevac
159.4800 stat medevac
151.52750 temple transport t 3
453.900 guthier air
155.1600 geisinger life flight 462.9500 life star
155.3250 geisinger life flight 166.9250 us park police eagle 1 dc
453.1250 geisinger life flight 160.020 de lifenet 61
155.2350 /allegheny life flight 151.800 de lifenet 61
155.3250 skycare 1 no longer flying 44.7400 maryland state police trooper 3
451.0250 sky care 1 no longer flying 47.660 maryland statle police trooper 3
155.2200 emergycare lifestar
464.2750 medstar
also try The eastern pa medcom channel med /vhf high ems
463.0250 med 2 155.2800
463.0750 med 4 155.3400 national calling channel ems
463.100 med 5 155.2200
463.1250 med 6 155.2950
463.1500 med 7 155.1750
463.1750 med 8 155.2050
462.950 med 9 155.1600
462.9750 med 10 155.2350
155.3250
154.2800 se pa fire ems national cahnnel
also try 800 interops
851.51250 interops 1
852.01250 interops 2
852.51250 interops 3
853.01250 interops 4
call or vist your local fd and see if they have a list laying around that u could get a copy
of ask ems to if they know which one of the helicopters is first due to cover your area that could have also gone with a trunk system in your area try that . put in all of your local fd and ems channels and listen there some go to ground channel ect. They also could have gone to the statewide p-25 or opensky system if they went open sky then u will not hear anything their as it is a celluar type system and no scanner can listen in just like psp went to. this is a i can give u try a serach online to
Cunnerman
Monroe County, PA
mattl3320 - Thanks for the additional frequencies.
However, I did have most of them and that wasn't really my question. Less than a week ago I could hear what I described above, the pilots talking to control (flight times, lbs of fuel, number of persons on board, etc); whereas while listening to the accident response on New Year's (Jan 1 2014) that was no longer available. I just wondered if they had made a switch. I appreciate your response and ideas to find out how to get the info IF the freq's had changed. I just was curious as the whether or not they actually DID. Thanks again though.
echo676
Exeter Pa
Medavacs
That the problem I seem to have...........very limited traffic anymore..........you don't hear the patient reports etc any longer ? I travel arond a bit for work through out Pa and have more than enough radios ( commercial Kenwwod dual bands & BC 996 ...all hard mounted MOT antennas ) in my trucks that I should hear anything that is going on............I am guessing myabe using CAD / Aplaha pagers or even smart phones or maybe Med Comm channels on simplex ?
echo676
Exeter Pa
Cunnerman......I was heading up NE extension........once I got thru the tunnel northbound I was able to hear Lehigh come alive
Cunnerman
Monroe County, PA
echo676 - Thanks for the report. I was actually very close to the Lehigh Valley Hospital today with my scanner and wasn't able to catch anything. Wrong place, wrong time I suppose. To confirm you heard Lehigh on 464.2000?
echo676
Exeter Pa
It's been a couple weeks.......I have both UHF freqs loaded from the freq list here I dowloaded.But it was Lehigh talking..... I don't hear anything down here in Berks
