CHIRP cause of Baofeng Problems REAL
I just went through TWO of these Baofeng BF-F8+ radios ruined by CHIRP.
Out of the box, all functions worked. I spent an hour testing the radio, talking to another on 70cm with success, listening to channels on scan . . . everything worked.
One plug into CHIRP and a quick upload of channel settings . . . the radio squelch no longer lets transmissions through.
No matter if the squelch on the menu was set anywhere from 0 (hearing static) to 9, absolutely NO AUDIO can be heard unless the monitor button on the side is held in. Before using CHIRP, even a squelch of 7 would allow another radio within the same room to be heard.
There is something wrong with CHIRP on this radio.
Like I said, I had a working radio, connected CHIRP, uploaded settings, then lost use . . . TWICE! I sent the radio back, got a replacement, and the same thing happened when I used CHIRP.
I really wish all of you would quit bashing the cheap Chinese radio. This Baofeng (all 3) unit was pretty nice until I took someone's advice to use this software to configure it. Please pay attention and fix this.
