Mobile compatible stream player
CMaas
Waupun, WI
Is there a embedded stream player that is compatible with mobile devices that do not use Flash?
I know there are apps that will play streams and I do have my web page identify mobile users and point them to the apps. It's not a big deal but I figured if somebody just wanted to listen and not have to install a app, it would be nice. Maybe once they listen and decide they want to tune in more often, then get the app.
http://hundehutte.no-ip.info/waupunscanner.html
GordonE
Live Audio Administrator
Flowery Branch, Georgia
You could point them to Broadcastify.com's mobile web site at http://m.broadcastify.com, they should be able to click on the link for the feed they want to listen to and listen to it using the device's native player.
frazpo
SW Mo
Gordon is correct. Are you wanting the raw address so that they can just use the iphone or droids player to play the feed?
You could then add that to your home screen without going through all the menus
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
Where
Where did you find the raw address for this feed?
