2009 Jetta and BCD436HP
tknepp32
Database Administrator
Fairview Township, PA
Photos of my 2009 Volkswagen Jetta TDI with BCD436HP installation. Also have a Garmin GPS attached and 1/4 wave VHF glass mount antenna on the windshield. Both the GPS and scanner are wired hot and I installed a kill switch below the dash.
russellmaher
KC1ANC
Enfield, CT
That looks good Tim.
How did you secure the scanner bracket where it enters the seam next to the radio?
Or is it just a press fit into the seam?
Anyway, how do you like the performance, and is it what you expected or more?
Russell
tknepp32
The bracket is a panavise bracket. It is a specific fit for the car. It shares screwed under the trim with the radio and the climate control.
tknepp32
And as far as the performance. I started with a BCD396XT when I got the car and then switched to a HomePatrol and just switched out to the BCD436HP. This is by far the best scanner I have had in the car so far. Simulcast decode is awesome compared to the other two and now I can pick up the Phase 2 system in my work area. GPS is awesome for the amount of driving that I do.
tknepp32
Thank you. It has done very well and surprisingly it is doing well for reception for all bands. I mostly monitor low band, UHF and 800.
dmg1969
Newport, PA
Nice install tknepp! Neat and tidy.
recon, go here. Toward the top, you will see any area to put in the make. It will then have several for Corolla based on the year. I looked at one for my HP-1 in my Tucson, but opted for a dash mounted RAM mount. PanaVise Products, Inc.
