FRCC Weld Co Upgrade Tue Night
rfburns
Sounds like Weld Co is upgrading sites tonight which requires taking them off the air. Tech at New Raymer now and another tech enrt to Grover. Standing-by for radio announcement to the rural fire agencies.
ScannerSK
Weld County, Colorado
Weld Sheriff reported a radio tech. arrived at one of the towers to work on it and will be there "all night".
Weld has started switching towers over to FRCC in part beginning with the Grover and Pawnee towers.
Shawn
ScannerSK
Site 536:
FileVersion:7
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 5AB
System Name :
WACN : BEE00
Tower Number (Decimal): 5-36
Tower Number (Hex) : T0524
Tower Description :
Control Capabilities : Data,Voice,Registration
Call Sign(s) : WQPZ636
Timestamp : Tue Feb 11 23:05:59 2014
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.00625,1
03,762.00625,0.01250,30.00000,"Confirmed",0.00625,1
04,935.01250,0.01250,-39.00000,"Confirmed",0.00625,1
05,935.01250,0.01250,-39.00000,"Confirmed",0.00625,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0039","i",851.25000,"00-0039",806.25000,0,1
"00-0145","av",851.91250,"00-0145",806.91250,0,7
"00-0209","a",852.31250,"00-0209",807.31250,0,0
"00-0303","a",852.90000,"00-0303",807.90000,0,0
"00-0379","c",853.37500,"00-0379",808.37500,1,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
522,"T0516",5ab,"01-1758",772.99375,""
550,"T0532",5ab,"01-1378",770.61875,""
551,"T0533",5ab,"01-1626",772.16875,""
ScannerSK
Weld County Simulcast (Site 330) went down at about 11:55 PM 2/11/14 and is still down at 2:12 AM 2/12/14 causing no little headaches for Weld dispatchers. Most portable radios not working, lots of digital... From the sounds of it Weld dispatchers do not realize the Weld County Simulcast cluster of towers is down. Radio techs reporting North Weld towers are being overloaded around 1:00 AM.
ScannerSK
Site 555:
FileVersion:7
-TowerInfo
System ID : 5AB
System Name :
WACN : BEE00
Tower Number (Decimal): 5-55
Tower Number (Hex) : T0537
Tower Description :
Call Sign(s) : WQML772
Timestamp : Wed Feb 12 03:06:01 2014
-Tables
-Frequencies
"01-1320","i",770.25625,"01-1320",800.25625,0,1
"01-1440","v",771.00625,"01-1440",801.00625,0,6
"01-1480","v",771.25625,"01-1480",801.25625,0,4
"01-1526","v",771.54375,"01-1526",801.54375,0,5
"01-1574","v",771.84375,"01-1574",801.84375,1,5
"01-1614","a",772.09375,"01-1614",802.09375,0,0
"01-1662","a",772.39375,"01-1662",802.39375,0,0
"01-1786","a",773.16875,"01-1786",803.16875,0,0
"01-1826","c",773.41875,"01-1826",803.41875,0,0
-Neighbors
525,"T0519",5ab,"00-0419",853.62500,""
527,"T051B",5ab,"00-0347",853.17500,""
536,"T0524",5ab,"00-0379",853.37500,""
ScannerSK
Site 527:
FileVersion:7
-TowerInfo
System ID : 5AB
System Name :
WACN : BEE00
Tower Number (Decimal): 5-27
Tower Number (Hex) : T051B
Tower Description :
Call Sign(s) : WPRZ902
Timestamp : Wed Feb 12 03:37:00 2014
-Tables
-Frequencies
"00-0183","i",852.15000,"00-0183",807.15000,0,1
"00-0273","av",852.71250,"00-0273",807.71250,0,12
"00-0347","c",853.17500,"00-0347",808.17500,0,0
"00-0459","a",853.87500,"00-0459",808.87500,0,0
-Neighbors
555,"T0537",5ab,"01-1826",773.41875,""
ScannerSK
Site 530:
FileVersion:7
-TowerInfo
System ID : 5AB
System Name :
WACN : BEE00
Tower Number (Decimal): 5-30
Tower Number (Hex) : T051E
Tower Description :
Call Sign(s) : WQRA932
Timestamp : Wed Feb 12 06:35:56 2014
-Tables
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
05,935.01250,0.01250,-39.00000,"Confirmed",0.01250,2
-Frequencies
"00-0005","vi",851.03750,"00-0005",806.03750,0,6
"00-0037","v",851.23750,"00-0037",806.23750,0,14
"00-0223","v",852.40000,"00-0223",807.40000,0,12
"00-0275","av",852.72500,"00-0275",807.72500,0,4
"00-0341","av",853.13750,"00-0341",808.13750,0,5
"00-0369","c",853.31250,"00-0369",808.31250,0,0
"00-0411","av",853.57500,"00-0411",808.57500,0,4
"00-0861","v",856.38750,"00-0861",811.38750,0,5
"00-1021","v",857.38750,"00-1021",812.38750,0,6
"00-1093","v",857.83750,"00-1093",812.83750,0,7
"00-1253","v",858.83750,"00-1253",813.83750,0,5
"00-1413","v",859.83750,"00-1413",814.83750,0,7
-Neighbors
558,"T053A",5ab,"01-1784",773.15625,""
ScannerSK
Site 558:
FileVersion:7
-TowerInfo
System ID : 5AB
System Name :
WACN : BEE00
Tower Number (Decimal): 5-58
Tower Number (Hex) : T053A
Tower Description :
Call Sign(s) : WQPB210
Timestamp : Wed Feb 12 07:06:04 2014
-Tables
-Frequencies
"01-1524","vi",771.53125,"01-1524",801.53125,0,2
"01-1572","v",771.83125,"01-1572",801.83125,0,81
"01-1612","av",772.08125,"01-1612",802.08125,0,54
"01-1660","av",772.38125,"01-1660",802.38125,0,9
"01-1784","c",773.15625,"01-1784",803.15625,0,0
"01-1824","av",773.40625,"01-1824",803.40625,0,1
-Neighbors
530,"T051E",5ab,"00-0369",853.31250,""
dirtfinder
Still in the middle of no where
FileVersion:4
-TowerInfo
System ID : 5AB
System Name :
WACN : BEE00
Tower Number (Decimal): 525
Tower Number (Hex) : T0519
Tower Description : New Raymer ( CDOT GARAGE HWY 14)
Call Sign(s) :
Timestamp : Wed Feb 12 07:30:36 2014
-Tables
-Frequencies
#Format: Channel,Usage,Frequency,Input Frequency
"00-0155","a",851.97500,806.97500
"00-0235","a",852.47500,807.47500
"00-0419","c",853.62500,808.62500
-Neighbors
rfburns
Sites and Control Ch
525, New Raymer, 853.625
527, Grover, 853.175
555, Ft. Lupton, 773.41875
536, Nunn, 853.375
558, SE Weld S. of Keensburg, 773.15625
530, Weld Simul, 853.3125
Spirit
Larimer County
FRCC
How do we put the FRCC's in the scanner? Can we still pick up FRCC? Do they go by CC's line numbers or just put in the CC no matter what order? I have all the CC's in my scanner that are in the DB for Weld County. I'm not familiar with FRCC.
ScannerSK
Adams County and Weld County switched over to a new radio system referred to as FRCC. If Weld or Adams county is your primary location and you do not plan to listen to other counties, you will want to update your system frequencies to the 9 system frequencies listed above plus any additional alternate control channels you might wish to add and remove any talkgroups for other counties. If Weld or Adams is not your primary listening location and you would like to add it as a new system to listen to, you will probably want to duplicate your existing DTRS system, rename it FRCC, remove non-Weld/non-Adams talkgroups and update the system frequencies. Personally, I have only the Weld Simulcast system control channel entered with its three alternate control channels.
I have found the Weld simulcast system is strongest at my location however the PSR-500/600 scanner will always navigate away from the simulcast control system frequencies to other weaker control system frequencies (if they are entered) due to the constant constructive/destructive signal strengths caused by the multi-path signals on the simulcast system. This occurs whether I have Multi-Site set to Roam (any settings) or even Off.
It seems the only way to monitor the simulcast system continually is to have only the simulcast system entered otherwise the scanner will navigate away from the simulcast system to a weaker control channel within five or ten minutes from my experience.
Shawn
nathancarlson
Longmont, CO
Thanks for those control channels! I may try that trick of taking out the other control channels. I can only get 772.99375 on my pro-106, and its not a very high decode rate. I live on the north side of Longmont. It seemed like I was missing a lot of traffic, so I may take out the ones that don't work (since I am stationary for a while) until I am able to start going mobile again, and I may have better luck.
Will there be a FRCC site near or at the Mead towers? That one always worked very well for me. The DTRS Bald North site works great in most of the areas when I am mobile, but I doubt they would have a site up there for this system. It has amazing coverage, though!
scanlist
Scanning since the 70's to today.
Greeley, CO
Closest to Longmont is the Tri-Town site 773.41875 CC (was Ft Lupton) on the old Broadcast Tower next to the KDEN TV tower east of Dacono in the area of S.H. 52 and Weld County road 17. I stay locked on it mobile while commuting through Longmont via S.H. 66.
I will miss Weld via Bald Mountain as it was the site I monitored at the daytime job.
Weld simulcast has most all of the Adams agencies showing up which was expected as the coverage is quite extensive primarily from the Road 54 Johnstown area water tank site.
Also UNC PD moved to FRCC.
dirtfinder
For the ones that want it here is the text file for Weld Cty FG tgs ... This is from Pro96Com taken from me switching through my FD radio .... Notice TG's 420-427
FileVersion:5
# Talkgroup List for this system
# Format: Talkgroup,Priority,Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),FirstSeen(Unix),FirstSeen(Human),FG Color,BG Color
# Priority Values: 0=Ignore, 1=Highest priority, 99= Lowest Priority
420,50,"NMAT 1",1392257451,"02/12/2014 @ 19:10",1392257362,"02/12/2014 @ 19:09","#000000","#000000"
421,50,"NMAT 2",1392257467,"02/12/2014 @ 19:11",1392257462,"02/12/2014 @ 19:11","#000000","#000000"
422,50,"NMAT 3",1392257481,"02/12/2014 @ 19:11",1392257474,"02/12/2014 @ 19:11","#000000","#000000"
423,50,"NMAT 4",1392257502,"02/12/2014 @ 19:11",1392257486,"02/12/2014 @ 19:11","#000000","#000000"
424,50,"SMAT 1",1392257651,"02/12/2014 @ 19:14",1392257642,"02/12/2014 @ 19:14","#000000","#000000"
425,50,"SMAT 2",1392257665,"02/12/2014 @ 19:14",1392257631,"02/12/2014 @ 19:13","#000000","#000000"
426,50,"SMAT 3",1392257675,"02/12/2014 @ 19:14",1392257670,"02/12/2014 @ 19:14","#000000","#000000"
427,50,"SMAT 4",1392257708,"02/12/2014 @ 19:15",1392257698,"02/12/2014 @ 19:14","#000000","#000000"
1907,50,"WC FD DISP",1392256587,"02/12/2014 @ 18:56",1392256560,"02/12/2014 @ 18:56","#000000","#000000"
1908,50,"GREELEY FG 2",1392256859,"02/12/2014 @ 19:00",1392256846,"02/12/2014 @ 19:00","#000000","#000000"
1909,50,"EATON FG 3",1392256879,"02/12/2014 @ 19:01",1392256860,"02/12/2014 @ 19:01","#000000","#000000"
1910,50,"WINDSOR FG 4",1392257218,"02/12/2014 @ 19:06",1392257208,"02/12/2014 @ 19:06","#000000","#000000"
1911,50,"AULT-PRC FG 5",1392256950,"02/12/2014 @ 19:02",1392256937,"02/12/2014 @ 19:02","#000000","#000000"
1913,50,"AMB DISP",1392256994,"02/12/2014 @ 19:03",1392256985,"02/12/2014 @ 19:03","#000000","#000000"
1916,50,"WC FG 23",1392256980,"02/12/2014 @ 19:03",1392256971,"02/12/2014 @ 19:02","#000000","#000000"
1919,50,"LASALLE FG 11",1392257148,"02/12/2014 @ 19:05",1392257139,"02/12/2014 @ 19:05","#000000","#000000"
1920,50,"MT VIEW FG 12",1392257116,"02/12/2014 @ 19:05",1392257103,"02/12/2014 @ 19:05","#000000","#000000"
1921,50,"EVANS FG 6",1392257168,"02/12/2014 @ 19:06",1392257158,"02/12/2014 @ 19:05","#000000","#000000"
1922,50,"NUNN FG 7",1392256893,"02/12/2014 @ 19:01",1392256885,"02/12/2014 @ 19:01","#000000","#000000"
1923,50,"FD/FIRES FG8",1392257098,"02/12/2014 @ 19:04",1392257077,"02/12/2014 @ 19:04","#000000","#000000"
1924,50,"HUDSON FG 9",1392257056,"02/12/2014 @ 19:04",1392257044,"02/12/2014 @ 19:04","#000000","#000000"
1925,50,"FT LUPT FG 10",1392257136,"02/12/2014 @ 19:05",1392257120,"02/12/2014 @ 19:05","#000000","#000000"
1926,50,"WINTAG 1",1392257301,"02/12/2014 @ 19:08",1392257292,"02/12/2014 @ 19:08","#000000","#000000"
1927,50,"WINTAG 2",1392257312,"02/12/2014 @ 19:08",1392257307,"02/12/2014 @ 19:08","#000000","#000000"
1928,50,"WINTAG 3",1392257322,"02/12/2014 @ 19:08",1392257316,"02/12/2014 @ 19:08","#000000","#000000"
1930,50,"WCSO",1392257568,"02/12/2014 @ 19:12",1392256793,"02/12/2014 @ 18:59","#000000","#000000"
1933,50,"PAWNEE FG 20",1392256778,"02/12/2014 @ 18:59",1392215181,"02/12/2014 @ 07:26","#000000","#000000"
1937,50,"NWRMR FG 21",1392256757,"02/12/2014 @ 18:59",1392256596,"02/12/2014 @ 18:56","#000000","#000000"
1941,50,"MILKN FG 16",1392257187,"02/12/2014 @ 19:06",1392257176,"02/12/2014 @ 19:06","#000000","#000000"
1942,50,"JHNSTWN FG 17 ",1392257202,"02/12/2014 @ 19:06",1392257192,"02/12/2014 @ 19:06","#000000","#000000"
1943,50,"GALETON FG18",1392256934,"02/12/2014 @ 19:02",1392256921,"02/12/2014 @ 19:02","#000000","#000000"
1947,50,"WC MAYDAY",1392257250,"02/12/2014 @ 19:07",1392257222,"02/12/2014 @ 19:07","#000000","#000000"
1948,50,"WINTAG 4",1392257332,"02/12/2014 @ 19:08",1392257327,"02/12/2014 @ 19:08","#000000","#000000"
1949,50,"WINTAG 5",1392257344,"02/12/2014 @ 19:09",1392257338,"02/12/2014 @ 19:08","#000000","#000000"
1950,50,"WINTAG 6",1392257356,"02/12/2014 @ 19:09",1392257349,"02/12/2014 @ 19:09","#000000","#000000"
1951,50,"FD M/A",1392257265,"02/12/2014 @ 19:07",1392257256,"02/12/2014 @ 19:07","#000000","#000000"
1955,50,"BRIGGS FG 19",1392256822,"02/12/2014 @ 19:00",1392256673,"02/12/2014 @ 18:57","#000000","#000000"
1956,50,"PLTVL FG 13",1392257071,"02/12/2014 @ 19:04",1392257059,"02/12/2014 @ 19:04","#000000","#000000"
1957,50,"SE WELD FG 14",1392257040,"02/12/2014 @ 19:04",1392257030,"02/12/2014 @ 19:03","#000000","#000000"
1958,50,"PLT VLY FG 15",1392256912,"02/12/2014 @ 19:01",1392256898,"02/12/2014 @ 19:01","#000000","#000000"
1963,50,"WC FG 22",1392256965,"02/12/2014 @ 19:02",1392256957,"02/12/2014 @ 19:02","#000000","#000000"
