Trouble with installing RTL2832U+R820T win7 64-bit
RelativeCode
I'm working under Win7 64-bit. I tried to install the drivers RTL2832U+R820T with Zadig.
attachment.php
While the driver is installed but I can not do it using SDRSharp software. When I open SDRSharp, can not find RTL / USB.
attachment.php
Please guide me where is the problem?
n0nhp
Grand Junction
Hit the down arrow next to the "Other(Sound card) and pick RTL-SDR / USB.
I tried to get a screen shot but the dialog box closes as soon as I press any other buttons.
Then hit play and you should have success.
Bruce
mikewazowski
Staff member
Forums Manager
Oot and Aboot
RelativeCode, your post should really be in the Software Defined Radio forum. If you'd like a mod to move it, use the Report Post icon in the upper right of your first post.
We don't move posts out of the New User forum unless the OP requests it.
RelativeCode
Sorry but I can't find "Report" button, for report move to "Software Defined Radio forum.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
It's the red and white triangle in the upper right corner of your post.
I saw your request in the thread and have already moved it for you.
rbm
Upstate New York
I'm running some of those dongles on a Win7 64bit machine.
Here are a few things that may help you.
When you run zadig, you should run it in 'administrator' mode.
When you start SDRSharp, you should select 'RTL-SDR / USB' from the drop down box.
Go to Control Panel, Device Manager
Under Universal Serial Bus Devices ..........
Look for 'Bulk-In, (Interface 0)
Make sure it shows the libusbx.org driver.
If so, you should be good to go.
If not, then the driver isn't installed.
If you are saying that you can't see "RTL-SDR / USB" in the drop down box ..
Then edit the 'SDRSharp.exe.Config' file and look for this line (between the quotes) near the bottom. (SDRSharp must NOT be running when you do that.)
"<add key="RTL-SDR / USB" value="SDRSharp.RTLSDR.RtlSdrIO,SDRSharp.RTLSDR" />"
Rich
