Mobile set-up on a 95 Geo Metro
riccom
My install, its a work in progress, btw, I am a worker on the c.n.so I am not a wacker, any opinions and idea are welcomed!
Sent from my EVO using Tapatalk
jasday
Ponder Tx
I normally refrain from negative comments, I'm a firm believer in Darwin, but that is a massive projectile on your dash.
svfd17
Spring Valley NY
Is that a stock vhf antenna? At first I thought it was a low band antenna.
Sent from my C570 using this tapatalk machinery
KG4INW
Midlothian, VA
That also looks like an SMA antenna, which your radio doesn't have an SMA connector. You'll burn it up if you TX much.
KG4INW
Midlothian, VA
Never mind, I stand corrected! Haven't had a 560 across my bench before but all of the 600s use the MX connector. Wonderful M.
slapshot0017
ITU Region 2
You work for Canadian National, live in Louisiana and have personal stuff on your radio? How does that work or is that not company issued? The only other non railroad frequencies I've ever seen on a radio was Amtrak and it was just the weather frequencies.
