All,
I think I need some serious help here. I have a very strange issue I need worked out. I have ARC536Pro and the Sentinel Software and have programmed two favorites lists--one for DC area and the other for the Baltimore area. Here's where things go awry:
-My scanner is installed in my car and I like to listen to it when driving around DC and to and from Baltimore.
-DC area favorite list I have as FL0 and Baltimore area favorite list I have programmed as FL1.
-In each FL I have approximately 10-14 systems programmed in for the various jurisdictions.
-All systems are avoided with the exception of System 0 which is local to my home.
-As I travel into each jurisdiction I want to use quick keys to avoid and unavoid the local systems to listen to.
-As I leave System 0's area, I use quick keys to avoid it then do the same thing to unavoid system 16 as I enter that county.
-Unfortunately, when I avoid or turn off system 0 in FL0, I lose all the other systems. I can turn them on or off, but the display says nothing to scan.
-When I check my programming in ARC 536, they're there and numbered as systems correctly as I intended.
-This happens if I use the menu to manually turn on or off these various systems, or if I use quick keys.
Does anyone have a solution to this, or feel that I may have a corrupted memory card? Thanks for any help.
