Jose_Rogers
Programming a 6350, for 100% receive only on all conventional channels with combination of Analog and Digital only.
In the software, it states: Rx only, "Configures the channel to receive only with out any transmission capability. All transmit features for the channel will be also disabled, except GPS Revert. This a channel wide feature".
(e.g. Emergency Rvert Channel) or TX Designated channel (e.g. the scan Tx designated channel)
When programming in "Rx Only" , because it will be used for as a scanner radio only. I do NOT want this radio to transmit, nor GPS, nor IP site control to produce any signal to cause any public service agency such as EMS,Fire, Rescue, etc... and any interference whether by accident or on purpose. What is GPS Revert ? I don't understand. Are they any thing else I need to check in the programming just to make sure this DOES NOT HAPPEN....Thanks in advance.....
