motorola roaming and connect plus?
K
kk4mei
Guest
Can someone give me a quick rundown on how to program my radio to roam and link to the best signal repeater on the DMR MARC ststem?
XPR 7550 radio using CPS 10
62Truck
Ordinary Subscriber
Uranus
On dmr marc they don't use connect plus. They use IPSC for roaming. Check their website and click on the "program your radio" link. All the info you need is there.
K
kk4mei
Guest
Okay so I can just make a roam list and that is all that is required? Will the radio automatically select the repeater with the best signal? Also do I have to add the frequencies to the channel pool?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
IP Site Connect is fairly easy to setup.
Make sure IP Site Connect is checked on every channel you wish to roam on, create a Roam list with the channels you want to roam on and go back to the channels and select your newly created roam list under Scan/Roam List.
