2013 Ford Fusion / RS Pro 160
wcr20
Volusia Co, FL
So - I had to sell my 2000 Explorer - where I had the scanner mounted on the end of an old cell phone goose neck.
I got a 2013 Fusion which has an odd cubby hole below the center stack - and I said to myself... "I wonder..."
Well, wonder no more!
(the cable you see in the side view is a usb phone charger, not related to the scanner)
The antenna is a black trunk lip low profile mount - right now its got a 460meg quarter wave on it - most of what i listen to is 800s though (Volusia County FL), so I may try a few other masts to see what works best.
Anyone have a black 800 meg NMO they want to donate to the cause?
It's really nice when you can easily do a low profile mount like that. I like radios, but I don't want them in my way. Looks like you found the perfect place.
Now if we can just talk you into drilling the hole for the antenna, I might just donate a black 800MHz whip to the cause.
yohshua
NYC
Nice install I like the low profile look and the scanner hides nicely in there.
wcr20
Volusia Co, FL
I'm considering it....
In my old days as an active 1st responder/EMT/Medic I wouldn't have hesitated - in fact my (purchased new) 1990 Suburban wasn't mine for 30 minutes before the headliner was down for 5 NMO holes plus another 2 holes for lighting.
I'm less prone to such outbursts now. ;-)
I might also consider a glass mount however.
03msc
RF is RF
The Natural State
If it's working properly and well for you then it looks good and that's all that matters.
wcr20
Volusia Co, FL
Update: the heavy duty 'plastic velcro' from Radio Shack just didn't hold up to the FL heat. I ended up adding a couple of small brackets to support the radio
PACNWDude
I have that same mobile/desktop scanner myself and it does look nice as part of a console. It looks like it fits well and looks like it was not an afterthought to put in there.
In my experience, people look right over scanners and amateur radios a bit if they look like they are part of the car these days. And you get less questions while driving around with windows open too. No questions about, what is that thing there for? Or, what do you listen to with that?
Thank you for sharing the pictures.
