Unitrunker Release 27
Release 27 (1.0.27.19) is officially out.
Highlights
1. Six receiver types: Signal, Control, Both, Inline, Debug, and RTL2832U.
note: only the R820T tuner chip is support on RTL devices.
2. Baseband audio receivers:
a. Selectable audio output for each.
b. Mute checkbox.
c. De-emphasis checkbox.
3. EDACS fixes.
4. Motorola enhancements - see Info tab on site and system windows.
5. P25 fixes.
6. Windows XP is now oldest supported OS.
General
Add control channel dwell time; persist dwell time and chase; chase logic fixed (for RTL at least).
Voice following fixes:
1. clone receiver crash (debug assert).
2. two or more voice receivers track same call.
3. voice receiver fails to switch when call moves to another channel.
Drop F11+F12 hotkeys.
Receiver run state didn't always show "Stopped" when stopped.
User's rank wasn't reloaded, trashed hits value.
Faceless receivers to be parked (tuned) at start-up in signal role (eg. Realtek and iCOM PC/Rs).
Fixed: duplicate log entries appear in the Site Log whenever the signal receiver is restarted.
Found some memory leaks; fixed.
Fixed crash near grid wizard popup when site window closed / destroyed.
Grid line flicker fix.
Decode properties weren't persisted.
Control channel "hits" also cleared when channel hits cleared.
Receiver types and roles revised.
Receiver health timer - pass down to tuner for inline models.
Receiver type enumeration.
Fixed persistence of receiver (wave / control / both / debug / realtek) devices.
Health timer for inline receivers.
Call grant event logic bug fixed (zero source ID).
Simplified Joins logic.
Fixed memory leak in site and system property sets (leaked dynamic properties).
Explicit destructors to aid debugging.
Fix memory leak caused by missing virtual destructor.
Add detection checkboxes to HP-1E and Debug receivers.
SiteView and SystemView's Info tabs did not initially display Site/Systems' persisted decoder properties until decoding underway.
Recognize lost signal event.
Fixed multiselect crash.
Update to new XML API (XML rewrite as published on codeproject).
Channel has control elapsed time counter.
Control counter for channels.
Join and Login text labels.
SetEndOfFile related crash dump file bug fixed.
Access code (NAC, connect tone, color code) weirdness.
Log file handle error.
Site window activation now limited to when site window does not exist.
- otherwise, active window (eg. UI editing) does not change.
- two active site windows won't fight for focus.
Greatly simplified resource manager.
Fixed enumeration of inline models.
Realtek USB Receiver
USB enumeration: earlier fix to suppress redundant interface to same device (Windows XP through 7) offered wrong device (safely ignores the second interface to IR port).
Persist signal port and listen port.
Enumerate wave output devices for combo list.
Drop volume from RTL2832U properties.
Fixed squelch scaling.
Support multiple wave output devices - device selection.
Lock-free improvements for Relay.
Fix: associating WinUSB with both interfaces on RTL stick causes device to appear twice.
Factory shutdown - only dispatch parting tuner events, not trunking events.
Added analog flag to suppress following analog calls (persisted receiver property).
USB enumeration fixes: look for "WinUSB" service.
Remove duplicated properties for RTL sticks.
Compose RTL device name.
Fix enumeration to work on Vista and hopefully XP and 7 too.
Fix bugs introduced with refactoring receiver objects to support Realteks.
Eliminate critical section for overlapped bulk IO; replaced with lock free queue.
Realtek via WinUSB; don't re-allocate bulk transfer buffers each time device is paused to change settings.
RF power based squelch.
Persist receiver "mute" setting; pass mute setting to receiver - signal or control.
R820T: calculate fractional N PLL register values: prescale, quotient, and remainder.
Implement Michael Karcher's explanation of RTL2832U FIR filter coefficients.
VCO sample rate for Tuners.
Oscilloscope notified of sample rate.
Make Inline a separate device type - basically a Serial device with some extra assumptions ("Both" receivers were being coerced into Inline).
Support float for Realtek warp setting.
Primitive SDR features down-sampling, filtering and narrow FM demodulation (no AM, CW or SSB).
Enumerate Realtek devices.
WinUSB layer for Realteks.
Baseband Audio
Remember mute for wave only devices.
'Scope tab for all wave inputs and Realtek and HP-1E.
Added mute; fixed resampler; avoid debug asserts.
Simplify setting oscilloscope "sink".
Wave project - wave audio recording, playback, and WAV file IO.
Wave writer (play audio) support; introduce eWaveOutput device class.
Fixed: separating eSerial and eInline resulted in inline receivers never starting.
No synthetic hearbeats for health reporting from inline models.
Fixed: set deemphasis at receiver start.
EDACS Decoding
Auto save interval was 60 hours, now 60 minutes.
Use new profiled hamming function.
Filter fix for EDACS48.
EDACS narrow support (1.8 and later firmware) for GRE.
Color code.
Call type and class missing for SitePro voice calls.
Motorola Decoding
Reports Smart Zone vs. Omni Link vs. other basic types.
Type 2i grant bug fix.
Logic revamped to track source ID and crack Type I address into source and target addresses.
Connect tone to "Tone" for generic display of site access code.
Make all site properties read-only.
Properties say "Enabled" or "Disabled" instead of "Yes" or "No".
Site property dispatch on actual change, not every two seconds.
Fixed, alternate CCs not populating for M36/P25 in Dedicated Lock mode.
Detect IR, simulcast.
Type II generic - better display site details.
Dozen dual OSWs previously displayed as "Unknown Dual".
Faster fleetmap lookup.
Don't show weird ASCII chars on incomplete site alias.
Regroup address.
Network and system status displayed as site into and system info.
Fleet map changes should trigger system property event.
P25 Decoding
Replace bit oriented CRC16 with byte oriented CRC16 based on Eric E. Johnson's published implementation.
Inhibit logged the wrong radio ID.
Fix EADS quirkiness.
Radio Check tweak.
Inhibit / Uninhibit backwards.
Deny reasons added; new queue'd reason table.
ISP table - unknowns show ISP opcode.
Acknowledge response tweaks.
Queue'd response now emits busy event.
Deny response tweaks - emits deny event.
Opcode $28 filter group ID 0.
RFSS Status class added to site info.
WACN and Sysid in system info.
Show opcode 9 load property.
Display MFID; display computed callsign for non-Motorola (radix 50 bug fix).
Display data related channel grants & simplified call type.
Call type formatting.
Display WACN, Sysid in system properties.
Display RFSS, site number, and LRA in site properties.
Fixed: on P25 signal drop - site window reactivated as if site was reacquired.
Enable filter for CQPSK.
Fixed: inline receivers falsely reported C4FM modulation for P25.
Fixed: download non Motorola 770 Mhz P25 system - program assumed standard Motorola bandplan.
Protocol Detection
Reenable DMR.
NXDN and DMR checkboxes.
NXDN split into NXDN48 and NXDN96.
New OpenSky 2 sync words.
OpenSky sync word.
OpenSky decoder checkbox.
OpenSky 4800 vs. 9600 baud.
Index of /download
Realtek
Installation
bravo14
Polk County FL
Highlights
Protocol Detection
Reenable DMR.
OpenSky sync word.
I updated the new release but not able to find the bcd396xt. I see BCD396T and UBCD396T.
puzzleriddle
bham, Bama
suggestion
make tops of each column sortable The ri'ds/tgids in numerical order & also target Ids's , is this possiible in an update maybe?
SRSP2282
Alachua County, FL
I noticed a bug while monitoring this SmartZone system Gainesville / Alachua County Trunking System, Gainesville, Florida - Scanner Frequencies
All calls have a “-” in the SVC column. Previously only analog calls were noted with a “-”. Digital multi selects are now showing up as “MS”. When I switch back to the old version 1.0.26.16 everything is displayed just fine. Its been a while since I upgraded so I tested out some of the other preview releases. Turns out the last release where the SVC column was displaying digital calls was 1.0.26.16.
Any thoughts? Is there a log file that I can send that would be helpful?
S
screamin72
Guest
I got the preview release 1.0.27.19. Do I need to download the official release? Is there a talk group hold for EDACS?
tbiggums
I tried installing this new version on an XP Home Service Pack 3 machine, and I get "The application failed to start because WINUSB.DLL was not found." error when I try and run it. I'm not using any of those USB RTL dongles, just receivers with discriminator taps.
I tried downloading the zadig XP version, but it doesn't want to install or extract. Maybe it wants to see one of those dongles first?
Is there anything I can do to get this to work with Win XP Home, Service Pack 3?
Create a new *inline* receiver. The XT models are visible there.
It's on the wish list.
Thanks. I'll check this out.
No. It's the same.
No, still no call holding.
Another user reported the same problem today. Windows XP SP3 is supposed to include WinUSB. I don't know what's going on.
tbiggums
I ran a search on the whole hard drive of the XP Home machine for WINUSB.DLL, and it didn't find anything.
Then I fired up my old XP Pro SP3 machine, and ran a search on it, and it found two of them. The newest version 6.0.6000.16386 was in C:\WINDOWS\SYSTEM32. I copied this file over to the XP Home machine, and now Unitrunker works!
I'm not sure if it was there as part of XP Pro, or if something else I installed on that machine put it there.
I hope most of the memory leak issues are fixed. I have been running three receivers simultaneously, and the memory usage would creep up to a couple hundred megabytes after 3-4 days.
Thanks for all your efforts with it!
nd5y
Wichita Falls, TX
I don't know what the EDACS fixes were supposed to fix but on one of the local systems I still get large numbers of killed/kicked radio IDs. I guess it is the way they (mis)configured their system.
My wish list:
In the receiver window decode section instead of just showing the protocol when you are monitoring a conventional repeater, add a line that shows P25 NAC and talkgroup, NXDN RAN, and DMR color code and time slot.
bravo14
Polk County FL
I got it going. When I did that I do not see the following
Reenable DMR.
OpenSky sync word.
Awesome!
Microsoft introduced WinUSB somewhere between XP SP2 and XP SP3.
Those modes aren't available from an Inline receiver - which limits you to whatever the radio's own firmware understands. You need discriminator audio. A tapped receiver, an HP-1E or a Realtek (with R820T tuner) will work. Understand that detecting the protocol only tells you that the buzz you hear isn't one of the trunking formats that Unitrunker actually decodes so it's not a major loss.
Clear the Denials checkbox to suppress that. There's an open task to trim back these redundant messages.
The NAC is shown on the Site window's Info tab - unless your receiver is an inline model. The program doesn't decode DMR or NXDN.
For the voice following receiver - the active group and radio ID are displayed at the bottom of the receiver window.
Someone asked for something similar. They wanted the Receivers tab to show which system was currently monitored by each receiver. That's on the list.
bravo14
Polk County FL
Thanks for clearing that up.
rock18
Question on the load value for a Motorola p25 system. I'm not seeing values that I expected. For example if the system has 5 talk paths and 2 are in use I expected to see 40% but it shows 24, as a third path becomes active the load number drops to 18. Am I just not understanding this field?
Sent from my ADR6400L using Tapatalk
The exact meaning of the load value is unknown. As you noted, it goes up & down with call activity. It isn't a percentage.
joeuser
The Wretched
North Central Kansas
So I'm wondering if anyone has a P25 specific guide?
To UniTRUNKER author - great work on this version & direct dongle interface, appreciate your work.
