Harris Unity XG-100 Initial Programming
TexasCOML
Houston, TX
First time programming Unity and it won't see the radio. Error says to make sure unity is in programming mode??? Any ideas how to put it in programming mode?
Thanks and sorry for such a basic question.
Thunderknight
Bletchley Park
USB cable? Did you install the USB drivers? From what I recall, Installation is two steps - install RPM and install the drivers.
If you are using the USB cable, programming is under the Unity device management in RPM. If it's the serial cable (mobile connection to rear of radio), the it's under standard (or serial) in RPM.
There is no "button press" to get into programming mode on the Unity I've ever seen. It goes into it when the upload or download starts.
OpSec
All your WACN are belong to us
Monitoring the database
There is no programming mode.
Open RPM, attach the cable to the radio, plug it into the USB port and turn the radio on. It's been a couple years since I dealt with initial setup, so I don't remember drivers, etc.
TexasCOML
Houston, TX
Programming
Well further info shows that the serial will not work with a USB to Serial adapter nor direct to the serial port of the computer. Had to bluetooth it so not sure if I have a bad cable or a bad radio.
Thanks for the help!
Anyone have the NIFOG in a code plug/template for this radio? New at Unity programming so that would help. No trunking, just the public info in the NIFOG.
Thanks,
