RTL sdr stream to radio reference
VA7DMZ
Creston, BC
I am thinking something like this on my linux box.
rtl_fm | sox | ezstream
Code:
/usr/bin/rtl_fm -f 146.8M -N -s 192000 -r 48000 -d 0 | sox -r 12k -t raw -e signed -b 16 -c 1 -V1 - -r 48000 -t mp3 - | /usr/bin/ezstream -c /var/radio/configs/repeater-146.800.xml
But it fails like this...
Code:
root@radio:/var/radio/scripts# /usr/bin/rtl_fm -f 146.8M -N -s 192000 -r 48000 -d 0 | sox -r 12k -t raw -e signed -b 16 -c 1 -V1 - -r 48000 -t mp3 - | /usr/bin/ezstream -c /var/radio/configs/repeater-146.800.xml
 Found 2 device(s):
  0:  Realtek, RTL2838UHIDIR, SN: 00000001
  1:  Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: ezcap USB 2.0 DVB-T/DAB/FM dongle
Detached kernel driver
Found Rafael Micro R820T tuner
Oversampling input by: 6x.
Oversampling output by: 1x.
Buffer size: 7.11ms
Tuned to 147088000 Hz.
Sampling at 1152000 Hz.
Output at 48000 Hz.
Tuner gain set to automatic.
Signal caught, exiting!
User cancel, exiting...
Reattached kernel driver
my pipe fu is weak. where is my error :(
VA7DMZ
Creston, BC
rosecitytransit
Portland, Oregon
Does just the rtl_fm command work? I know Windows hates having identical devices with the same serial number, but Linux may be smarter about that.
The "Signal caught, exiting! / User cancel, exiting..." seems like the program thinks you're stopping it.
VA7DMZ
Creston, BC
I compiled the rtlsdr software from latest source and tried again.
I tried using a simple rtl_fm | play command and it does the same thing you noticed.
Code:
# rtl_fm -f 162.5M - | play -t raw -r 24k -e signed-integer -b 16 -c 1 -V1 -
Found 2 device(s):
Using device 0: Generic RTL2832U OEM
Tuned to 162752000 Hz.
Oversampling input by: 42x.
Buffer size: 8.13ms
Exact sample rate is: 1008000.009613 Hz
Sampling at 1008000 S/s.
Output at 24000 Hz.
Segmentation fault
The program seems to think I am exiting it. I am not doing anything that sends it a exit signal...
Segmentation fault
I dont think this should be here either.
rosecitytransit
Portland, Oregon
Try unplugging one of the dongles. The -d command may tell rtl-fm which device to use, but it won't help Linux tell them apart. If that helps and you really need to use both, use rtl_eeprom to change the serial number on one of them.
VA7DMZ
Creston, BC
I finally got it working. It turns out the lame and ezstream binary were corrupted.
I reinstalled with "apt-get remove lame ezstream && apt-get install lame ezstream"
Code:
root@kali:/var/radio/configs# rtl_fm -M wbfm -f 139M -d 1 -r 22000 | lame -r -s 22.0 -m m - - | ezstream -c /var/radio/configs/RADIO-139.000.xml
Found 2 device(s):
Using device 1: Generic RTL2832U OEM
ezstream: Connected to [url]http://audio3.radioreference.com:80/xxxxxxxxx[/url]
ezstream: Streaming from standard input
Tuned to 139010000 Hz.
Buffer size: 8.03ms
Exact sample rate is: 1020000.026345 Hz
Sampling at 1020000 S/s.
Output at 170000 Hz.
Now it streams the data to radio reference. :D
The next task would be to try removing the static. some kind of software squelch.
S
screamin72
Guest
you have to do lsmod command in terminal then see if rtl is listed. Then blacklist.conf the lsmod rtl results sudo your editor too save to etc/modprobe.d folder reboot your distro.
eg....blacklist rtl_2832
save as rtl_blacklist.conf into etc/modprobe.d
if you do not want to reboot simply unplug the usb dongle then plug it back in. then run
rtl_test
it will look like it is frozen when in fact it is working (happens with R820T tuner). press ctrl + C at the same time to exit it.
Hope this helps
slicerwizard
Toronto, Ontario
Did you ever get squelch working? I can't seem to make it work for me
The squelch logic in rtl_fm is terrible. Same deal with the bandpass filtering. Better not have any nearby signals. Well, if the squelch doesn't work, I guess the filtering issue is moot anyway.
