computer doesnt recognize scanner
Gar45
Aldie, Va
ok. So I have purchased another usb cable for the scanner. I was able to update the DSP firmware but when I try to update the CPU firmware,the computer doesnt detect the scanner. I followed the prompts telling me to turn off the scanner and press menu while plugging in the cable. But when I click the check for updates button I get that message. Any help is appreciated.
krokus
Southeastern Michigan
Are you using to correct firmware? For instance, you cannot load the RadioShack firmware into the GRE branded radios.
Sent via Tapatalk
Gar45
Aldie, Va
yes, krokus, I have the correct firmware. Puzzleriddle, I will give that a try. Thanks.
Gar45
Aldie, Va
well installing the port drivers didnt help either. I am at a loss for what to do next.
Swipesy
Northern Ohio
I don't know if this will help or not. You should always update the CPU first and then the DSP. Try installing the DSP for the CPU version you have installed. Then try the new CPU version and see if it works. It is odd you can update DSP and not CPU. Same cable.
Gar45
Aldie, Va
when I check version I get the following: boot ver: F1.0 App1 U1.8 are these the latest? Also the screen reads CPU SW upgrade: waiting for USB...my laptop recognizes the sd card but the software for GRE doesnt see the scanner on any port.
KW4HKY
Hickory, NC
You need to go to the above link and download the correct driver. After that you need to go to program manager and make sure you choose the correct number usb port on the scanner software
Gar45
Aldie, Va
I downloaded from the link you posted. Then I went to device manager and tried to update the drivers for the scanner but it said it couldn't find them. I had the computer search in the area they were downloaded to and it still says the same thing. This is a losing battle. ;(
dleland
Whitmore Lake, MI
I may of missed it, but what's the model of your scanner and what is the OS on the computer? Are you using RS232 or USB?
W1JCW
Bryan, Tx
USB Driver PSR 800
I'm trying to get my scanner software working on a new LT. It wont recognize the USB cable / device. I've downloaded the CDM V2.10 driver and no luck.
I've moved it around on usb ports but it just shows up as Unknown.
Virtual COM Port Drivers
Any ideas ??
Running Win 7 64
Gar45
Aldie, Va
My scanner is the psr-800 and I have windows 8.I also tried the scanner with a windows 7 machine and I had the same problem. Funny how this didnt happen til GRECOM went out of business:(.
W1JCW
Bryan, Tx
Yes all drivers are up to date. Usually I can search around and find the driver and update the unknown device but not this time.
There must be a driver or something out there as I know others have the same issue.
I have the program loaded on my another PC with win xp 32 and it works fine.
ScannerSK
Weld County, Colorado
W1JCW portion of the this thread
I'm trying to get my scanner software working on a new LT. It wont recognize the USB cable / device. I've downloaded the CDM V2.10 driver and no luck.... Running Win 7 64
I noticed at the bottom of the GRE Download Website <http://www.greamerica.com/support/> there are two USB PC/IF Datacable 30-290 Drivers. I’m not sure if they would help in your situation or not?
By “new LT” are you referring to a GRE PSR-800 scanner?
Shawn
