Another learning experience
When you say that you are transferring the HPD file, do you mean that you are actually (manually) transferring that HPD file from your computer directly to the SD card in the scanner via the mass storage mode (or a card reader) and Windows Explorer.
Or are you using Sentinel to "write" to the scanner after making those entries in the "display options" tab in the Sentinel "profile editor" and saving the changes?
Tnx for your reply. I have an update regarding my issue. Actually "hpd" was my typo. Although after creating one partially (Only one entity "append from" is needed) completed favorite list in Sentinel Software I can use Butel ARC536PRO to create, edit and write favorite lists to the 536. The changed file saved and written was a Sentinel Software updated profile "hpe" file via a "Mass Storage" USB interface..
I am very familiar using ARCXT PRO and 396XT and 996XT software which is very easy to use for files creating, editing and transfers. I dread having to use Sentinel Software for anything, but I had to for certain initial basic file setup requirements. A few weeks ago I finally created a successful profile and one partial favorites list. Then using Butel ARC536PRO I successfully imported selected ARC XT files and created "hpd" favorites files and subsequent writing to the 536.
After my post I searched the RR archives and found a Sentinel Software setup checklist someone had posted months ago for a "nothing to scan" file issue. In Sentinel Software I sight checked each RR checklist item and noticed one requirement was to have service type "Custom 1" checked. I had not initially checked "Custom 1" service type because I don't have any custom service files. I selected "Custom 1" anyway and saved the "hpe" file and did a file write to the 536. That is all I changed.
I powered the 536 off and then on. Guess what? Now the text message displayed correctly. Sentinel Software also had changed my display option but I knew how to change it for my preference.
When I selected "Help" in Sentinel Software my help was "Version 1.02 (Revision 01)" .
Another learning experience. Tnx. again for your reply.
John
