Boom Mounted Pre-Amp with the ST-2 Antenna
cmed325
essex county massachusetts
Need info on using a boom-mounted amplifier with a ST-2 antenna,I have no experience with these. I would like some feed-back on what to get,And how they work,And do you need a power source?
rbm
Upstate New York
That's a short question that takes a LONG answer. ;-)
Yes you would need a power source for any preamp.
Here's an old thread that discusses how to power your preamp.
http://forums.radioreference.com/sc...wering-versus-remote-powering.html#post860180
As long as you don't have any very strong signals in your area, it's worth experimenting with an antenna mounted amplifier.
As for what to get, well that can go from around $20 or so to well over hundreds of dollars.
Here's a link to a cheap experiment.
http://forums.radioreference.com/sp...-4-1-4-way-splitter-question.html#post2134894
While the noise figure of that amplifier isn't the best, I've used to to show some friends locally what a preamp can do for them.
This is another view of a similar setup with approximate prices etc.
Mount the amplifier at the antenna and leave out the splitter if you don't need it.
http://forums.radioreference.com/sc...antennacraft-st2-scantenna-5.html#post2015393
Rich
And .... Here are some of my 'spare' amplifiers.
And another thread about getting power to your preamp.
http://forums.radioreference.com/sp...uplers/286451-800-meg-preamp.html#post2153364
k9rzz
Milwaukee, WI
First you've got to ask yourself: If there is a nearby lightning strike, and it blows the pre-amp up on the mast, can I get it down easily to replace it? My opinion from working with weak signal SSB/CW ham type stuff on 6,2, and 432 .... unless you're 100% hardcore in copying the weakest of the weak signals, then I would just put one in the shack. SO much easier to swap in/out or fix when broken, and it still helps copy the weaker signals. Don't get me wrong, I'm still PRO pre-amps, but just use it in the shack.
