free scan upload compatability
CQdeKS1E
Waltham, MA
Got a 996T all set up with a freescanupload. Works great. A neighbor of mine has a996Xt, so my question is can I use my 996T program and upload to the 996XT without problems? Thanks in advance.
hiegtx
Dallas, TX
Sure.
I have found that, in changing between scanner types (assuming that you're going to load his scanner using your pc), you sometimes get an error, "limit exceeded", "scanner full", or something else. (This does not always happen, but happens enough to make you scratch your head.) What I do to avoid this when switching among my various DMA scanners is, during the upload process, click on the port setting, and hit the auto detect. FreeSCAN will then "find" the port (which didn't actually change), but more importantly it will also recognize the scanner model connect is not the same as was present for the previous session (your 996T).
Of course, there are settings available for the 996XT, such as the display color, that do not apply to the 996T. Those do not have to be set in order to use your existing file.
737mech
Clark County, NV.
Remember also the 996t is only 6000 channels the 996xt is 25000. Usually not a problem but I ran into that with my bct15 at only 2500 vs my 15x at 9000.
hiegtx
Dallas, TX
True, but the OP is wanting to use an existing 996T file for the 996XT, so that should not be an issue.
wx5uif
Broken Arrow, OK
The only problem I have had between using the same file for the 996T and 996XT is that they GPS locations are stored differently in each.
The XT needs the GPS info for each site / group where as the T needs it per system.
hiegtx
Dallas, TX
Also the "T" does not do multiple sites like the "XT" does.
Actually, it does. The 996T does have multi-site. The 396T does not, so if cloning a 396XT file to a 396T, if there was a multi-site system in the 396XT, FreeSCAN would create a separate system for each site, duplicating the talkgroups.
