Updated my home desk scanners and radios
firemedic2150
Senior Member
Right here...
Did a little updating to my desk at the house after seeing Rich W9JIG do his racks, I could not afford to do what he did but I did get a second 3 scanner rack for my radios and new BCD996XT.
The desk is a Hon desk I bought at a scratch and dent sale 10-12 years ago, The computer is a Dell tower I have had for long time running dual 21" Dell widescreen monitors.
The left rack has my VHF and UHF CDM1250 radios and in the top is a BCD996XT I picked up a few weeks ago at the local Radio Shack for $99.00! that I am using as my general scanner right now for what ever strikes my mood. The right rack has another older BCD996XT that scans the TVRCS Chattanooga P25 simulcast. The top BCT15X right below it scans the older Chattanooga/Hamilton County system. Things are locked out in each so they do not duplicate things that are on both systems. The bottom BCT15X is mainly for area conventional scanning. On top of the right rack is a Icom ID880H Dstar radio which is on the W4PL system in Chattanooga most of the time, The Kenwood TMV71A under it is my general use radio. I am having a hard time managing the two microphone cords for the amateur radios.
The BCD996XT on the left and the two BCt15X scanners are connected to a older ST2 antenna in the attic using a Stridesberg 4 port multicoupler. The other BCD996XT has a tuned 800 Mhz rubber duck portable on a right angle BNC to avoid P25 simulcast issues. the Kenwood TMV71A is connected to a Comet GP-3 in the attic. The Icom ID880H is connected to a comet B-10 mounted to a NMO drilled in a 16 inch pizza pan in the garage. And the UHF CDM1250 is connected to a Sinclair UHF antenna in the attic. The VHF CDM1250 to a homemade J pole in the attic.
03msc
RF is RF
The Natural State
NICE setup and you got a deal on that 996xt! Thanks for sharing your station with us. Inspiring!
EDIT: Since you have dual displays, check into DisplayFusion for spanning wallpaper across both screens or using a different wallpaper on each - they have a free version or a paid version. Just a suggestion if you're interested!
WatnNY
Knoxville, TN
Well that answers my question if the CDM's will fit in those scanner desk top mounts! Looks like I may have to order another one to put my CDM's in!
Mike
firemedic2150
Senior Member
Right here...
WatnNY,
You will need about a 1/2 spacer for each side they are just over and inch narrower than the scanner stand. I went to Lowes and got some 1/2 inch thick poly washers and some longer metric screws to mount them, and it still pulls the sides in just a bit, I could add just a regular washer and probably make it fit better but its not bad.
slapshot0017
ITU Region 2
How did you find the scanner for so cheap??? I will go pick one up for myself if this is the case in most places! Sweet setup too!
JimmyL1011
Chicago
Hey FM2150....where'd you get the racks you use to hold your radios? Looks pretty sweet. I could use 4 to keep misc radios. Inquiring minds wanna know.
iMONITOR
Silent Key
S.E. Michigan
Looks great! Very compact, yet fully functional. I like those 3-tier stands. I have one BCD996T, and two BCD996XT's...tempting!
