Baofeng UV5R Programming Help Question.
westsac95691
Trying to enter the frequency (via radio) 452.18750 into the baofeng uv5r and it just jumps the frequency to 452.185 Not sure what im doing wrong here. Please help
Kd9bku
Noblesville, indiana
I have one also, you need to go into the menu and change the STEP so that you can put in the correct frequency. I think if you change it to 2.5 you can get any number you need. Also as a suggestion, get the programing software and cable, it makes it so easy.
E-542
Lancaster, PA
Aye, the cable and software does; HOWEVER it's pretty important to know how to hand-program these 'on the fly' for emergency use. Yeah I agree with the first poster, your problem is your step-spacing is too broad. just change that to a smaller number(I usually leave mine at 2.5) and you're good to go. :)
robertmac
And here I thought that outside the ham bands, the radios could not be field programmable. Flame.
nd5y
Wichita Falls, TX
As far as I know all Baofeng radios are front panel programmable on any frequency out of the box and only a few Wouxun models are ham band restricted.
nd5y
Wichita Falls, TX
The step spacing is half the problem. The other half is the fact that the radio will not accept anything but 0 or 5 in the 3rd decimal place (6th digit entered) so you must have the right step (menu 1) and use the up/down arrow keys to set the 3rd, 4th and 5th decimal places.
Kd9bku
Good point!! I should revisit the programing procedure
