Wrting a program in C++/Java/Ruby for DMR/MOTOTRBO/NXDN
voxiso
Somewhere, Kentucky
I need some beta testers.. I am about a month away to need some testers.. I am working on a program that will decode in real time.. With a record feature.. I will be sending out a beta soon.. Who wants to test it out for me?
Saint
Fort Erie Ontario Canada
Digital Systems
I have NXDN 4800 AND 9600 SYSTEMS I listen to, also TRBO, DMR, MOTOTRBO,DMR Motorola Connect Plus (TRBO) I am now using DSD+ and DMR DECODE to listen to these systems.
Steve
tikev
Quebec, Canada
Hi,
I can test it for you if you need. I have NXDN 4800 and 9600, iDas, MotoTRBO Conventional, Connect+, Capacity+ and Linked Capacity Plus sites around here.
Thanks,
Tikev
motohead10
Tennessee
I've decoded a 6.25 kHz NEXEDGE trunked system using an icom F4161DS scanning the channels passively programmed conventionally I also hear you can decode the radio IDs and talk groups but I haven't got that far into figuring that out yet
voxiso
Somewhere, Kentucky
NXDN is all and good at this time..Well 80% I need a few more weeks to do some testing on my own before I release anything.. The front end would be a 396xt, it will be a active front end, Also decoding at "real" time it may at times depending on the system and how many systems it could cause some what of a lag but only a a few seconds.. DMR I am still having issues with.. I am near real time but MotoTRBO I am still having major issues. Anyone with MotoTRBO knowledge PM ME
dumpRF
Hi,
Thanks for answer on this forum, i can get more information on "active front end" and do you use discriminator tap ? Thanks.
Best regards,
dumpRF
F5NVG
FRANCE
Test
I am ok
73 From F5NVG Pascal
vince48
Central Valley, CA.
I like to be a tester. We have quite a mixed bag of NXDN 4800/9600, MotoTRBO Conventional, Connect+, Capacity+ and Linked Capacity Plus systems that are monitorable here the SF bayarea.
vince48
voxiso
Somewhere, Kentucky
MotoTRBO is causing a major problem.. I wont lie I can not seem to find a fix for it.. I am looking into it tho..I got question about what I said about the front end..Once you install the program it will look like a 396xt it will also allow users to add their own database but more than 5 systems will cause a 3-10 sec lag on decoding at times and it will lock up.. Looking at that now.. I am now working on NXDN exclusive now.. Later will come the others.. In my area Hopkinsville, Ky PD is what I am using as a test. Which is fully NXDN.. Good results so far.. Other systems not so much.. I may give a screenshot this week. Stay tuned..
sirsmiley
Ontario
Will you be showing control channel data for trunking or just outputting voice? I have LTR, TRBO and NXDN in my area
Thanks.
